Author Topic: Renault 19 16v Brakes  (Read 2164 times)
LazaRs
« on: 15:22, Sun 08 May 2011 »
HI guys i have got a wrecked Renault 19 sport 1.8 16v, Can i fit the brakes from it onto R5 GTT ?
If i can what needs to be changed ??
THanks!
Re: Renault 19 16v Brakes
« Reply #1 on: 15:27, Sun 08 May 2011 »
Quote from: "LazaRs"
THanks!
Believe the 19 16v has same brakes as the Clio 16v, the caliper is identical to gt turbo only the caliper carrier is little longer so you can fit the slightly bigger diameter disc (259mm).
You'll need a minimum of 14" wheels on the 5 if you do go for them.
LazaRs
« Reply #2 on: 15:43, Sun 08 May 2011 »
THanks!
Thanks mark, but which brakes you recommend for the GTT ? I have seen some K-tec kits, i donno if they good. Do you know any ebay shops that supply good brakes for the good value of money ?
THanks mate!
« Reply #3 on: 16:10, Sun 08 May 2011 »
For me the gt turbo set up is fine with a good set of discs and pads, no need to go bigger brakes.
