Author Topic: 1000W Sub and Amp Installation  (Read 4367 times)
ljelliott
« on: 13:34, Wed 20 April 2011 »
I have been given a 1000W sub and a 1000W amp and have fitted both of these before to other cars, my own and other friends cars, but never a R5, I have all of the equipment for it, but i am not sure how to lead the battery wire from the battery to the inside of the car?
Thank you for your time
Re: 1000W Sub and Amp Installation
« Reply #1 on: 14:07, Wed 20 April 2011 »
I have mine going through the bulkhead towards the fusebox area, then tucked away along the passenger side behind the plastic trim. You can see the wire underneath the rear bench when it's lifted and then on into the boot.
ljelliott
« Reply #2 on: 14:37, Wed 20 April 2011 »
Thanks that seems simple enough, have you got the RCA cables running down the same section or on the drivers side?
« Reply #3 on: 19:41, Wed 20 April 2011 »
Mine run down the drivers side.
I thought it would be best, does the power lead interfere with the audio leads? I'm not 100% sure so i kept them separate anyway.
bigdur
« Reply #4 on: 20:12, Wed 20 April 2011 »
It can do, power cables create a magnetic field (electro-magnetic flux) and the RCA can pick this up in the form of interference in some cases. Always better to keep them apart.
ljelliott
« Reply #5 on: 22:06, Wed 20 April 2011 »
Yeah thanks that's what i thought, i've had to run them down the middle of some cars to stop them interfering with the air con leads. Thanks for your help i'm sure it will go fine, hope i can help you out at some point
