Author Topic: Turbos  (Read 2768 times)
kalve 5 gt tub
Turbos
« on: 22:48, Fri 15 April 2011 »
What Cars can you get a turbo off that will fit on my R5? Im looking for a T25 or a T28 garrett turbo!!!
Do the 200sx s13 t25 turbos fit?
Re: Turbos
« Reply #1 on: 22:54, Fri 15 April 2011 »
If your after a direct swap over there are none out there, there are avfew out there that will fit with alittle alteration (oil feed mod, housing rotation or housing swap) but what you go for will depend on engine spec.
kalve 5 gt tub
Re: Turbos
« Reply #2 on: 23:18, Fri 15 April 2011 »
I have already got a t28 on it but it needs rebild!! Im running a high compression engine!!!
If not does anyone know were i can get my turbo rebuilt in the midlands area?
Re: Turbos
« Reply #3 on: 23:26, Fri 15 April 2011 »
Quote from: "kalve 5 gt tub"
If you have T28 already its prob better speced up then a standard T28 off a production car, i'd say get your one rebuilt mate.
Can't think of anywhere near you but i get turbo's rebuilt at good price depending on whats gone on them down my way
smithyr5gt
Re: Turbos
« Reply #4 on: 17:50, Sat 16 April 2011 »
Hay fella CR turbos are very good. I had my t25 done there.
Posted it to them and the posted it back the next day.
kalve 5 gt tub
Re: Turbos
« Reply #5 on: 16:37, Sun 17 April 2011 »
Have you got a contact number for them? It only needs the oil seals doing i think
bluntyr5gtt
Re: Turbos
« Reply #6 on: 06:21, Tue 19 April 2011 »
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Ramair Induction Kit
cosworth 2wd Intercooler
Lowered 50mm
