Author Topic: wheel bearings  (Read 3335 times)
rsweeney
wheel bearings
« on: 13:37, Fri 15 April 2011 »
hey guys , renaults up and running insured it for a year today! only thing thats annoying me is when i drive there is a noise from the back of the car, the faster you drive the faster the sound gets. does this mean the wheel bearings need replacing, if not what else could it be ?
Re: wheel bearings
« Reply #1 on: 14:06, Fri 15 April 2011 »
new rear bearings needed fella
if your pads and discs need changing best do them together with the bearings as the new wheel bearings need to be pressed into the discs
rsweeney
Re: wheel bearings
« Reply #2 on: 14:18, Fri 15 April 2011 »
ok but the rears are drums not disks so is it harder to do ?
will it need both sides doing and where can i go to get the bearings
Re: wheel bearings
« Reply #3 on: 15:35, Fri 15 April 2011 »
drums? strange my 5 has discs
for the price of new bearings you might aswell do both of them
gsf is good for parts
rsweeney
Re: wheel bearings
« Reply #4 on: 17:37, Fri 15 April 2011 »
cheers , and yeah turbo models have disks all round non turbos front disks + rear drums
will see what gsf want for rear bearings- will i need too use new circlips atall?
Re: wheel bearings
« Reply #5 on: 17:51, Fri 15 April 2011 »
Quote from: "rsweeney"
ahh i see
new bearings should come with new clips :)
rsweeney
Re: wheel bearings
« Reply #6 on: 18:02, Fri 15 April 2011 »
they only list rear bearings for turbo models
http://secure.gsfcarparts.com/shop/results.asp
Re: wheel bearings
« Reply #7 on: 18:04, Fri 15 April 2011 »
Rear bearings should be easy enough to source from any motor factor place, they may even be same as clio as they use drums also.
rsweeney
Re: wheel bearings
« Reply #8 on: 18:21, Fri 15 April 2011 »
ok, will the bearings etc be the same as for the R5 turbo ?
Re: wheel bearings
« Reply #9 on: 18:29, Fri 15 April 2011 »
Not too sure mate, i recon gt turbo discs will have different design bearing compared to the campus drum but its worth checking
rsweeney
Re: wheel bearings
« Reply #10 on: 18:51, Fri 15 April 2011 »
found some , these should shouldnt they ?
