Author Topic: Need some help  (Read 2267 times)
kalve 5 gt tub
Need some help
« on: 21:32, Tue 12 April 2011 »
My fuel pump has stopped workin today but i let the fuel run low so could it be blocked?
If so hows the best way to clear it out without replacing it?
Re: Need some help
« Reply #1 on: 22:38, Tue 12 April 2011 »
As far as i know it's a sealed unit?
I suppose you could take it off and try and clear any blockages? I'm sure the fuel filter is between the petrol tank and the fuel pump so i doubt there is much in there?  :?
kalve 5 gt tub
Re: Need some help
« Reply #2 on: 05:10, Wed 13 April 2011 »
You can here the fuel pump makin a sound when the car trys to start but it domtnseem to be sending any fuel to the carb!!!
Re: Need some help
« Reply #3 on: 15:13, Wed 13 April 2011 »
checked the fuel pump relay ?
DaveMayGTT
Re: Need some help
« Reply #4 on: 15:26, Wed 13 April 2011 »
filter blocked?
Re: Need some help
« Reply #5 on: 15:31, Wed 13 April 2011 »
If the fuel pump is working then won't be the relay
If you have run it really low you sure you not run out of fuel, i'd be sticking about 10l of fuel in it then trying again. If not remove pump and filter and give then quick clean inside.
kalve 5 gt tub
Re: Need some help
« Reply #6 on: 21:10, Wed 13 April 2011 »
Fuel pump has just give up the ghost!!! Even with power goin to it it dont work!! Ive had volt testers on the wires and there is power at yhe end of them!!
Taken fuel pump off and tried running it off the battery and nothin happens so its just packed up!! Spoke to the lad tho and its the original fuel pump so needs upgrading anyway due to the bhp increase!!
Ive ordered a sytec motorsport fuel pump which will cope with 250bhp
Re: Need some help
« Reply #7 on: 22:04, Wed 13 April 2011 »
If the Syntec pump is same or greater flow then the phase 1 fuel pump it'll work ok, don't worry about bhp claim of the pump its all about fuel flow.  :wink:
kalve 5 gt tub
Re: Need some help
« Reply #8 on: 05:41, Thu 14 April 2011 »
The flow is greater than the original one mate!!
