Author Topic: Do universal pillar pods fit the 5??  (Read 8102 times)
Re: Do universal pillar pods fit the 5??
« Reply #15 on: 13:13, Wed 13 April 2011 »
Darn, i can't see youtube at work :( :(
BabyBluGTT
« Reply #16 on: 13:23, Wed 13 April 2011 »
Gah just spoken to him and its only the gauge. Nevermind  :(
« Reply #17 on: 14:12, Wed 13 April 2011 »
Quote from: "BabyBluGTT"
That's a shitter, gauge is usless without the boost solenoid
BabyBluGTT
« Reply #18 on: 16:23, Thu 14 April 2011 »
The company sent me a double instead of triple! I cant see how youve done it James, cut the pods out individually and put a bead of glue on the paper thin edges?? Did you sand them down completely? If I sand too hard ill go through!
« Reply #19 on: 18:27, Thu 14 April 2011 »
The advert should have got you a 3 pillar pod I would go back and tell them.
Mine stated like this
once got them position I glued them into place left over night in airing cupboard so glue can harden then I slapped on filler, fibreglass etc to smooth it all in.
BabyBluGTT
« Reply #20 on: 19:09, Thu 14 April 2011 »
Ah i suppose the tape helps to get it lined up properly :) Nice one mate
BabyBluGTT
« Reply #21 on: 21:48, Thu 14 April 2011 »
Do you think id get away with just using filler? Never used FG before and i think filler would be enough.
« Reply #22 on: 08:45, Fri 15 April 2011 »
Yeah don't see why not I only used fibreglass as I damaged it when fitting so used it to strengthen it all up :)
Don't forget to put some holes in the back for wires to run through :) I used a 42 mm holesaw drill attachment to do mine :) after I had the pod locations sorted
BabyBluGTT
« Reply #23 on: 13:48, Fri 15 April 2011 »
Quality, ill crack on with this on monday when i have my free afternoons ;)
