Author Topic: new renualt 5 memeber :)  (Read 5295 times)
rsweeney
« on: 18:46, Thu 07 April 2011 »
hi guys im the owner of a renault 5 1990 :) non turbo :( its relatively low mileage - 86,000.
want to go turbo but need advice and guides on prices ?? headgaskets being replaced at the moment with new valve stem seals. new dizzy, rotor arm, ignition barrel ht leads and oil.
Re: new renualt 5 memeber :)
« Reply #1 on: 19:12, Thu 07 April 2011 »
Welcome along mate.  :D
Turbo conversion on the campus is easy, done 3 myself. You looking to doing it yourself?
rsweeney
« Reply #2 on: 19:14, Thu 07 April 2011 »
yeah all works being done by me, so what things do i need to do and what price am i looking at ? not to make it sound simple !
« Reply #3 on: 19:20, Thu 07 April 2011 »
Well off top of my head you will need
-complete engine with carb and turbo
-all hoses
-rad
-intercooler
-exhaust system
-fuel pump
-fuel pressure regulator
-fuel sender unit
-AEI unit
-various brackets
There prob few more bits but all depends on what you want to change and how much power you want run
Price wise is really how much you can pick it all up for, sometimes for pennies sometimes cost's little more
If want abit of insperation here's pic of my old one which i built last year
rsweeney
« Reply #4 on: 20:18, Thu 07 April 2011 »
ok, that does look good! so i need another engine ? rather than mine - 1237cc 1990 ? the parts cant just be put onto the existing engine?
if so whats the best way to get hold of bits as im in guernsey
« Reply #5 on: 20:24, Thu 07 April 2011 »
Quote from: "rsweeney"
No the standard 1237cc engine isn't buillt up for turboing, compression too high for starters, oil pump not strong enough and few other bits. Its easier to drop a complete turbo engine in as its eaiser and more up to the job.
Most can be sourced off ebay or when he's back fromholiday have a word with Mike (phase 1 16v turbo), he runs gt turbo spares and will have absolutely everything you will need. He;s based near southampton too so abit eaiser for you.
Say i sent you and he'll sort you out, if you get stuck i'll pm his number for you so you can ring when he's back
rsweeney
« Reply #6 on: 21:18, Thu 07 April 2011 »
right i see will need to save some money aside or might just sort out the renault , back to its former glory.
i need the little spline bit the windscreen wiper arm attaches to.
drivers wing mirror. manual in grey
heater fan
radiator. :)
modfather
« Reply #7 on: 09:35, Fri 08 April 2011 »
welcome to the club mate  :)
i myself have done the camparse to turbo conversion too,i had to get all bits (listed above) and some more bits ie relays for the fuel pump and you will need the driver side interior loom for the fuel pump. when i done mine i chanced everything subframe , torsion bar, suspension, brakes, gearbox, driveshafts, exhaust system, electric window motors. getting the parts shouldnt be to hard most members have spares
rsweeney
« Reply #8 on: 18:24, Fri 08 April 2011 »
flip you didnt do it by half measures !
after considering the different parts of it im deciding to just restore the renault 5 to normal.
this way i can then maybe sell it on and start a turbo build.
im really struggling for parts atm though where can i go
as renault are asking stupid prices like  70 for wing mirror casing etc...
modfather
« Reply #9 on: 21:01, Fri 08 April 2011 »
 :lol:
what parts do you need i got a couple 1.4 campus bits left, front hubs, dials, gearbox, driveshafts possible some hoses and switches
rsweeney
« Reply #10 on: 09:31, Sat 09 April 2011 »
the radiator, thermostat, heater fan, drivers wing mirror, ?
any of these would be great.
modfather
« Reply #11 on: 10:02, Sat 09 April 2011 »
pritty sure that i chucked the rad and fan out a while ago but i think i do have a thremostat could be a low temp 1 aswell, im off out in a mo i will have a look when i get back  :)
rsweeney
« Reply #12 on: 08:13, Sun 10 April 2011 »
that would be great if you have it
modfather
« Reply #13 on: 11:39, Mon 11 April 2011 »
sorry for the delay,i have found a thremostat and have tested it and it works drop me a pm if you want it mate  :)
rsweeney
« Reply #14 on: 11:52, Tue 12 April 2011 »
is this the right dizzy for my 1990 renault 5 1.2
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
and are the the right leads
the new leads just seem very tight in the distributor where as they are fine in the old
