Author Topic: Engine out, cam and flywheel change  (Read 6552 times)
DeanGT5
Re: Engine out, cam and flywheel change
« Reply #15 on: 18:25, Wed 23 March 2011 »
It definately seems better top end, Do you have to remove the compressor housing to measure it? I noticed today that the inner water feed near the exhaust flange is leaking a little water. Can I do away with the water feed, because to replace the washers I would have to spin the exhaust side around
« Reply #16 on: 14:06, Sun 27 March 2011 »
Quote from: "DeanGT5"
Yes you do have to remove the housings to measure the wheels exactly
I personaly would leave the water feeds on as they're there to cool the turbo down, your be ok to rotate the housing round abit to remove the union to replace the washer
300+5=love
« Reply #17 on: 12:25, Wed 04 April 2012 »
if you haven't done the cam yet, if you remove the all the pushrods you can use magnets to to lift the cam followers and get the cam out without removing the head.
DeanGT5
« Reply #18 on: 16:20, Wed 04 April 2012 »
Hi
Thanks but ive had two engines since then  :lol:
