Author Topic: Driver Side driveshaft removal  (Read 2698 times)
Chadster
« on: 17:02, Sat 05 March 2011 »
what is easiet and quickest way of removing the whole driver side drive shaft out of the gearbox
Re: Driver Side driveshaft removal
« Reply #1 on: 18:07, Sat 05 March 2011 »
Undo 30mm hub nut, undo the 2 bolts holding the hub to strut then lpull driveshaft out hub. Push pin out the inner driveshaft cup which secures it to the gearbox shaft, slide it off them it'll be out
Chadster
« Reply #2 on: 18:48, Sat 05 March 2011 »
thanks bud,
going to take the hub off anyway as wanna strip wishbone and subframe and paint them etc
