Author Topic: can you tell me the name of this cable/what its for?  (Read 1269 times)
« on: 17:29, Sat 12 February 2011 »
coming from the gearbox (passenger side) next to driveshaft.
Re: can you tell me the name of this cable/what its for?
« Reply #1 on: 17:31, Sat 12 February 2011 »
Looks like the same position as the reversing light switch. But i'm sure the plug is different to that.  :?
« Reply #2 on: 17:57, Sat 12 February 2011 »
thanks Ash, thats interesting cos I dont have a working reverse light but I was doing some inversigation for my non-working speedo and dont have my haynes at hand untill I get back to the flat.
Well I can see that the connector from the gearbox, inside the plug there is only 1 pin! But on the connector it joins, it has connections for 2 pins! :shock:
« Reply #3 on: 18:39, Sat 12 February 2011 »
Looks like reverse light plug mate, if your switch in the box only has one connecter then thats broken and will need replacing if you want reverse to work.
« Reply #4 on: 18:43, Sat 12 February 2011 »
thanks for the info guys. Atleast now I can describe to mike exactly what I need now :D
