Author Topic: Reading Problems  (Read 1739 times)
Reading Problems
« on: 18:11, Mon 31 January 2011 »
alright guys im still looking for the right wideband.... found this one
http://prosportgauges.com/digital-air-f ... gauge.aspx
theres a bit at the bottom in red that im not  to sure about  :oops:
NOTE: This cannot be used as a stand along wideband AFR with a bosch wideband 5 wire heated O2 sensor unless you are using a controller! (If you need a complete wideband kit see our Wideband AFR gauge kits here: http://prosportgauges.com/wideband_AFR_Gauge.aspx)
is this basically saying i still need to by the actual wide band computery bit.. and this is just a gauge??
thanks for the time  :D
Re: Reading Problems
« Reply #1 on: 19:12, Mon 31 January 2011 »
I would say that it is the guage only.
« Reply #2 on: 19:49, Mon 31 January 2011 »
nice one..  :lol:  feel a bit silly now  :oops:  could u recommend any WIDEBAND CONTROLLER's ??
thanks  :D
danboi2
« Reply #3 on: 20:10, Mon 31 January 2011 »
« Reply #4 on: 21:36, Mon 31 January 2011 »
Quote from: "danboi2"
Hi pete the aem is a good one
http://www.efi-parts.co.uk/index.php?productID=204
i dont think i need the gauge with it, just the sensor and the dater logger bit  :oops:
