Author Topic: Turbo Garrett GT2854R  (Read 2058 times)
LazaRs
« on: 20:45, Wed 26 January 2011 »
HI guys, what do you think of this turbo? the link is below/  I am thinking of doing my GTT up to 220 bhp,
My specs are at the moment:
Fully Rejeted Carb,
Full 2.5" exhaust,
Large FMIC
STD cam
Uprated Pistons and Steel liners
Metal Headgaskets
Full Rebuild of the engine has been done.
Here is the Link for that turbo!
http://www.turbobygarrett.com/turbobyga ... 1171_9.htm
Thanks!
Boostjunkies
    • http://www.boostjunkies.co.uk
Re: Turbo Garrett GT2854R
« Reply #1 on: 01:04, Fri 28 January 2011 »
Well the larger GT2860R Disco Potato has been used for the R5's a few times so it should be fine
« Reply #2 on: 16:29, Fri 28 January 2011 »
Quote from: "Boostjunkies"
I don't know anyone running a disco potato on a C1J road going GTT....
bluntyr5gtt
« Reply #3 on: 07:08, Sun 30 January 2011 »
i remember a guy who used go by the name of turbotoaster had a gt28rs on his 5
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Ramair Induction Kit
cosworth 2wd Intercooler
Lowered 50mm
gt alan
« Reply #4 on: 12:39, Tue 01 February 2011 »
is that not going to be a tad bit laggy no??? like when are u gonna see full boost at about 4000rpm
bluntyr5gtt
« Reply #5 on: 16:22, Tue 01 February 2011 »
most t28s are about 4k so i believe
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
