Author Topic: Would these fit my 5?  (Read 6387 times)
BabyBluGTT
« on: 19:48, Thu 16 December 2010 »
OK Chaps i dont kniow anything about wheels really but i want something deepish with stretched tyres to get an awesome stance..
Seen a few cheapys that i really like just wondered if they would fit?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Thanks muchly
mjc
Re: Would these fit my 5?
« Reply #1 on: 20:12, Thu 16 December 2010 »
Sorry i have no ideal if they fit but i like the first ones how come your going for 13s instead of 15s
BabyBluGTT
« Reply #2 on: 21:06, Thu 16 December 2010 »
Just trying to be a bit different mate really, might end up going for stretched tyres so i thought 13s would look quite good :) What you think?
binge
« Reply #3 on: 23:12, Thu 16 December 2010 »
First ones are Mini Starmags. STUNNING wheels. But IIRC the PCD is 4 x 4inch. Good old imperial mini,  :)
I ran Allycats on my old mini, Stunning wheels!
Ben
« Reply #4 on: 15:15, Fri 17 December 2010 »
Quick answer for you mate, none of those wheels will fit. They are all wrong offset and PCD for the R5.
BabyBluGTT
« Reply #5 on: 18:22, Fri 17 December 2010 »
Cheers mark, what offset and pcd do i need to look for? after some small ones maybe banded but definately something that will look stanced :). Cheers matey
« Reply #6 on: 19:49, Fri 17 December 2010 »
The PCD is 4x100, offset wise standard is 35mm but if your going for the euro look you'll be wanting lwider than 7" and poss slightly smaller offset too. Remember the wider a further you push the wheel out the arch the closer it'll be getting to the arch.
BabyBluGTT
« Reply #7 on: 20:14, Fri 17 December 2010 »
BabyBluGTT
« Reply #8 on: 22:14, Sat 18 December 2010 »
Would they ^^^^^^^
BabyBluGTT
« Reply #9 on: 02:08, Sun 19 December 2010 »
« Reply #10 on: 11:21, Sun 19 December 2010 »
Quote from: "BabyBluGTT"
http://cgi.ebay.co.uk/Weller-wheels-/280605715201?pt=UK_CarParts_Acc_Wheels_tyres_Rims_Car_Wheels_ET&hash=item4155676b01#ht_500wt_904
Id change the tyres obviously :D
No they won't either, no Ford or Peugeot wheel will fit a Renault
« Reply #11 on: 09:34, Mon 20 December 2010 »
I thought the Mini's used 4x100. But 13j would never fit in the arches.
« Reply #12 on: 17:13, Mon 20 December 2010 »
No Mini's and Metro's run a different PCD, can't remember what it was but sure it wasn't 4x100.
BabyBluGTT
« Reply #13 on: 21:06, Mon 20 December 2010 »
Think ill just stick with the speedlines for a while as nothing seems to fit! :shock:
« Reply #14 on: 22:12, Mon 20 December 2010 »
Vauxhall and Volkswagon wheels fit, you will need to check the centre bore and offset though. My multispokes came off a Mk2 Golf.
