Author Topic: My luck must change soon ...  (Read 3986 times)
« on: 14:51, Thu 18 November 2010 »
t must be time for my luck to change.
Since owning it I have changed.
Air filter
Exhaust
Downpipe
TDC sensor
Renix ( ECU )
DriveShaft
Gearbox
Manifold
Turbo
Radiator ( x2 )
Intercooler
Degassings --> Matrix water pipe ( rubbing on alternator belt )
Water pump return to expansion chanber pipe ( rubbed on unguarded fan )
Water Pump
Swirl Pot
Window Latches
Clutch
Flywheel
Starter Motor
Horn
Engine Mounts
Gearbox steady
HT Leats
Dizzy
Front Bumper*
Rear Bumper*
It now has decided to sound like its firing on 3 cylinders on idle. I suspected an intake manifold leak. Can you get an intake manifold on its own ? Can you buggery. I have to take out the exhaust manifold as well. I have a slight saving grace as it appears a stud has gone walkabouts from one corner of the manifold. I am going to try and bolt it back together and hope the sucking stops.
After taking that lot apart I dropped a bolt in the cars bay somewhere. I have absolutely no idea where it has gone , and short of removing the engine I will never ever find it.
I walked round the back of the car and noted the smell of fuel. I now have a weeping reserve fuel tank.
The only saving grace is the fact that there is literally not a lot left that I haven't
( a ) bought new - or -
( b ) must be >< close to having a car that will work for a month at a time.
I must be due some luck with it.
* due to being gash
Re: My luck must change soon ...
« Reply #1 on: 15:25, Thu 18 November 2010 »
Andy, the exhaust & inlet manifold is just one gasket, I have a fairly new metal type Inlet / exhaust gasket if you need it in good condition obviously used but only done a max of 200-300 miles, yours if you want matey can post out tomorrow :) FOC - pm your address, I may even have some manifold studs and bolts spare aswell again will chuck in package if I can find some. :D
Andy sounds like me to be honest, can't think of one thing on my 5 I haven't replaced for new but I keep going through engine's  :lol:
« Reply #2 on: 19:12, Thu 18 November 2010 »
Why are you complaining with such a short list?
I dread to think back over everything i have had to do.  :lol:
« Reply #3 on: 19:38, Thu 18 November 2010 »
I have to write these things down just to check my sanity. My wife thinks I am mental. I think I am mental. Then I realise there are other mentalists out there.
You lot.
You have no idea how much encouragement you lot have on this 31 year old !
 :D
MATT BLACK
« Reply #4 on: 13:20, Fri 19 November 2010 »
lol - welcome to the world of owning a 20+ year old Renault hot hatch.
« Reply #5 on: 14:40, Fri 19 November 2010 »
Its crazy , I owned one 8 years ago , then a 21 turbo and now again another 5.
How do I keep on forgetting the issues ?
« Reply #6 on: 18:26, Fri 19 November 2010 »
Quote from: "andybond"
I am turning 31 this coming monday and I have had a renault 5 gt turbo since I was 18 years old in fact my first car was an Freg R5 GTT in tungy grey (F901 NBY).
There addictive my other half things I am fecking mad it's just a constant money drain even though 95+% of my car is new :lol:
« Reply #7 on: 23:40, Sat 20 November 2010 »
Went out to get a reserve tank today.
Now fitted and not leaking. Whoo ! Its a start.
billythewhizz
« Reply #8 on: 20:46, Sun 21 November 2010 »
i know how you feel, it seem's most of the thing's i've had to fix is a result of previous owners cockup's! surley it has to come to an end soon,there can't be alot left to fix or replace!!!!
« Reply #9 on: 21:14, Sun 21 November 2010 »
In all honestly , there really isnt a lot I can replace.
Only the block ..
H150GTT
« Reply #10 on: 00:30, Mon 22 November 2010 »
Only the block ..
I hope you havn't just scudded yourself saying that!!!
You got a spare block lying around???  :lol:
Thats like something that would happen to me....
I tend never to give the 5 any praise or think to myself thats it all sorted now cos you can bet 5 min later it will have something wrong with it  :roll:
R5's and wemon...  So alike at times lol
« Reply #11 on: 07:33, Mon 22 November 2010 »
TBH the block is cracked and held together with the finest chemical metal known to man ..
« Reply #12 on: 08:31, Mon 22 November 2010 »
Fecking hell handy I would be looking into getting a decent block spare just in case.
« Reply #13 on: 09:29, Mon 22 November 2010 »
When it knackers completely ( its only a little crack ! ) Ill look at full engine change.
Until - well lets just say the oil is stopping the underside of the car corroding ! :
 :D
