Author Topic: Fuel pressure regulator  (Read 1789 times)
LazaRs
« on: 18:21, Sat 09 October 2010 »
Hi everyone, i am fitting in my car a new tank polished with new uprated pump.
I would like to know if its possible to put some aftermarket fuel pressure regulator since i need to change my one. or i would have to fit the original???...
like this one:
http://cgi.ebay.co.uk/Fuel-Pressure-Reg ... 1478wt_906
Thanks guys!
Re: Fuel pressure regulator
« Reply #1 on: 18:31, Sat 09 October 2010 »
The original works well enough so no real need to change it, unless its for a new original one.
LazaRs
« Reply #2 on: 22:36, Sat 09 October 2010 »
Where can i find the new original one?? Do you think if i would order aftermarket one with gauge that it will do the same job?? Or i will need to get specific one >??
Thanks!
« Reply #3 on: 22:59, Sat 09 October 2010 »
Quote from: "LazaRs"
Thanks!
Mike (phase 1 16v turbo) from here can source you one, he's a parts supplier.
A standard one will do the job fine, if you found you needed more fuel pressure you can always tap the vacum reference pipe off the turbo compressor housing rather then the carb top this will give you few extra psi over boost pressure while on boost.
