Author Topic: oil warning light  (Read 1512 times)
doggydowg22
oil warning light
« on: 14:24, Sat 09 October 2010 »
Hello all
What would make the oil warning light come on,It isn't getting an oil pressure reading at all so assumed this would be the cause ie loose conection.
After some reading apparently the two arn't linked,getting abit worried now,the oil could do with a change as its thin,and the oil is topped up enough.
Engine pulls like a train so hoping this is an electrical fault I can find?
Any tips on where to look at for dodgy wires?
Thanks
Re: oil warning light
« Reply #1 on: 18:41, Sat 09 October 2010 »
There are two different setups.
1. Oil pressure gauge and low oil pressure light use the same sender/wiring.
2. Oil pressure gauge and low oil pressure light have seperate senders and wiring.
Follow the turbo feed down to where it joins the engine block, you should see the sender/senders there.
doggydowg22
« Reply #2 on: 08:27, Sun 10 October 2010 »
sender is there wires have been cut and touching on radiatot  :roll:
