Author Topic: no fuel  (Read 2172 times)
karlr5
no fuel
« on: 23:57, Tue 05 October 2010 »
I can't seem to get any fuel to my carb so a new relay and pump have been ordered,is there anything else I should need to check,thanks
Re: no fuel
« Reply #1 on: 08:12, Wed 06 October 2010 »
Have you checked for spark? If there isn't it could be the TDC sensor.
karlr5
Re: no fuel
« Reply #2 on: 21:45, Thu 07 October 2010 »
Yeah I got a spark but the fuel pump is dead but its working fine if I connect it to the battery,even had the fuel line off while starting and not one drop of fuel,changed the relay and there is no blockage to the pipe as I have had a mouth full of fuel
Re: no fuel
« Reply #3 on: 22:00, Thu 07 October 2010 »
If the fuel pump works and the relay is new then there must be a break in the wiring somewhere.
doggydowg22
Re: no fuel
« Reply #4 on: 08:42, Sat 09 October 2010 »
I had this once,check under the rear seat there is a wire that goes to the fuel pump is and check these arn't broke.As a temp fix you could run power to the wires here straight from the battery to get the pump working.
Re: no fuel
« Reply #5 on: 15:51, Sat 09 October 2010 »
Quote from: "doggydowg22"
Under the seat thats not the fuel pump, thats the fuel sender unit which has 3 wires coming from it.
doggydowg22
Re: no fuel
« Reply #6 on: 17:29, Sat 09 October 2010 »
Maybe this was part of an alarm imobiliser defnetly had to run live feed to wires to get pump working,sorry if this isn't the case for a standard 5 bad advise there on my behalf  :oops:
Re: no fuel
« Reply #7 on: 18:30, Sat 09 October 2010 »
I think he meant you have to lift the seat and pull forward the carpet, the fuel pump wire feeds through there.
