Author Topic: t25?  (Read 3257 times)
xcore
t25?
« on: 21:14, Tue 06 July 2010 »
alright chaps how easy is it to fit a t25 to a r5? iv got one on at the mo but need another as this ones blown
is it worth the gain over a t2?
cheers
Re: t25?
« Reply #1 on: 21:33, Tue 06 July 2010 »
The car feels more 'lively' with the T2 fitted because of the lower amount of lag.
I suppose the main question is how much boost you plan to run.
xcore
Re: t25?
« Reply #2 on: 22:16, Tue 06 July 2010 »
currently running 17/18psi
xcore
Re: t25?
« Reply #3 on: 12:41, Wed 07 July 2010 »
had a quick read and it all seems pretty straight forward for the swap, just the oil feed, can you get adaptors from somwere like Pirtek? im worried drilling and tapping might get some swarf in the turbo itself
cheers
Re: t25?
« Reply #4 on: 21:42, Wed 07 July 2010 »
Pirtek will make you an adapter for the oil feed.
For the drain try to get the metal pipe included with the turbo (if it's the Rover T25's your looking for). This can then be cut to length and attached to your existing rubber hose. I'm sure you can buy the oil drains new anyway, probably best asking around some turbo sellers or search on eBay etc.
xcore
Re: t25?
« Reply #5 on: 01:04, Thu 08 July 2010 »
cool the cars running a t25 from a 200sx s13 at the mo i may be able to take some bits of fthat, to join the oil pipe from the rover turbo to the oil lines on the 5 (11 in my case) would you just slip the rubber pipe from the r5 over the rover metal one and jubily clip it? sorry stupid qu!
Re: t25?
« Reply #6 on: 06:08, Thu 08 July 2010 »
Yes, exactly that.
xcore
Re: t25?
« Reply #7 on: 12:55, Thu 08 July 2010 »
cheers for help mate life saver!
garya
Re: t25?
« Reply #8 on: 23:03, Fri 09 July 2010 »
pirtek 14 for the union and adapter i got one when i fitted my t25 mate.
RENAULT 5 GT TURBO CAMPUS
