Author Topic: my five.  (Read 23320 times)
Re: my five.
« Reply #60 on: 19:23, Fri 16 March 2012 »
gutted....... I thought you had sneakily got away with it  :cry:
You gonna keep it running till it can run no more? buy another or do a swift bottom end rebuild?  8)
Re: my five.
« Reply #61 on: 21:10, Fri 16 March 2012 »
Technically its now knocking its fucking tits off.
I swear down its the box / clutch / flywheel tho. It really sounds like its coming from there ..
Sounds like something metallic sloshing around ...
Re: my five.
« Reply #62 on: 21:22, Fri 16 March 2012 »
Quote from: "James5"
Quote from: "Brigsy"
The knocking is probably down to the low oil situation before mate..
I am with Brigsy on this matey, damage has already been done :(
<fingers in ears >
LALALALALA
Re: my five.
« Reply #63 on: 22:51, Fri 16 March 2012 »
Quote from: "andybond"
The sound of oval crank journals, mangled bearings and a sump full of oil?
My engine is noisy, always has been. Sounds more 'top end' in my case though.
Re: my five.
« Reply #64 on: 23:07, Fri 16 March 2012 »
I can picture a bearing in lots of bits sloshing around.
Going to drop the oil , remove the sump and hope like hell nothing hasnt kaput.
Re: my five.
« Reply #65 on: 07:05, Sat 17 March 2012 »
like this  :lol:  ( hopefully not though )
Re: my five.
« Reply #66 on: 09:26, Sat 17 March 2012 »
That is almost exactly what I am imagining.
5campusturbo
Re: my five.
« Reply #67 on: 13:46, Sat 17 March 2012 »
fingers crossed for you chap. :)
Re: my five.
« Reply #68 on: 19:07, Sat 17 March 2012 »
I am not going to open up this engine till its got a replacement in the engine bay.
With the cost of repairs ( bearings etc ) its better to just bang another unit in there.
I am hoping to use a new style of VELCRO engine mount so when this one goes bang it will be less to unbolt ..
Re: my five.
« Reply #69 on: 16:55, Sun 18 March 2012 »
This is fun.
Been speaking to brigsy - could be a multitude of things. Going to whip out the engine and check flywheel is tight ..
I think its a flywheel bolt trying to make a bid for freedom ..
Have a listen. I can make it knock or not just about on demand.
Its at no1. end.
http://www.21toc.com/ab/one.MOV
http://www.21toc.com/ab/two.MOV
http://www.21toc.com/ab/three.MOV
http://www.21toc.com/ab/four.MOV
Re: my five.
« Reply #70 on: 21:49, Mon 26 March 2012 »
Been out today and burnt my head in the sunshine !
Engine is undressed and ready to be lifted out.
Re: my five.
« Reply #71 on: 22:55, Sun 15 April 2012 »
Engine back in again , but rain stopped play before I could refit everything.
Also bought a VNT ..
Re: my five.
« Reply #72 on: 08:15, Mon 16 April 2012 »
Andy, you will love the VNT once you have it setup to how you want it, boost like a T2 yet the pull of a T3 you will run out of rev's before the VNT stops pulling aswell even with a cam
Re: my five.
« Reply #73 on: 08:43, Mon 16 April 2012 »
Literally cannot wait !
hughesrobert13
Re: my five.
« Reply #74 on: 21:23, Sun 22 April 2012 »
hi guys what car do you get a vnt from i know the vag use them is there one in particular that you use ? cheers rob
Every day is a school day !
