Went for a spin in her last night.
There is still a slight rumble, maybe i was right before about one of the rear wheel bearings on its way out aswell, bit annoyed but i suppose it's about time i treated it to some new rear discs anyway, i don't see much point in just changing just the bearing because the rear discs look a bit tatty anyway.
Bucket seat sits perfect, a bit lower then standard but not too low it makes your legs uncomfortable, i will put the passenger side in over the weekend.
Car seems to handle a lot better now with less wheelspin in the wet. I had a look at the trackrod ends while the front was in the air and the one side was a good 3mm shorter then the other. I adjusted them so they were even both sides and measured the distance inside the wheel both at the front and back and evened them up as best i could.
I know it's not as accurate as the garage with the lasers and what not but it's a damn sight closer then it was, maybe now i wont shread the inside of my tyres as much.
