Author Topic: boost gauge help  (Read 2705 times)
turbo5collins
boost gauge help
« on: 13:39, Sat 20 March 2010 »
possibly a stupid Q, but where is the fuel regulator on the raider engine as im trying to fit a boost gauge and manual boost controller
i have been staring at the engine for hours and can't work it out lol
oops
any help is much appreciated, cheers
Re: boost gauge help
« Reply #1 on: 14:51, Sat 20 March 2010 »
Quote from: "turbo5collins"
oops
To fit a boost gauge and boost controller you don't need to find the fuel reg.
The boost gauge will T into the vacum line from inlet manifold to the AEI unit, boost controller will plumb into the vacum pipe from the actuator to carb top.
turbo5collins
« Reply #2 on: 15:08, Sat 20 March 2010 »
ok thanks for that i bin lookin at it for ages tryin to find were it goes lol
turbo5collins
« Reply #3 on: 15:10, Sat 20 March 2010 »
sorry  where would i find the vacum line from inlet manifold is that the one that comes of the carb
« Reply #4 on: 15:18, Sat 20 March 2010 »
Easy way to find it is find the vacum pipe that comes out the AEI unit mate, this goes to the inlet manifold so T into this pipe to fit the boost gauge
The AEI unit is the unit behind the bulkhead which the king lead connects to.
turbo5collins
« Reply #5 on: 22:38, Sun 21 March 2010 »
thanks for that i got it all done now works great  :D
« Reply #6 on: 15:33, Mon 22 March 2010 »
With the in-car boost controller, what boost you turning it up to?
turbo5collins
« Reply #7 on: 12:01, Tue 30 March 2010 »
its runnin 14 psi its a lot better now  :D
« Reply #8 on: 15:48, Tue 30 March 2010 »
On a standard carb thats the max you can go, after that the carb will need tweeking to fuel correctly.
