Hi ,
as mentionned you can check all the connections and the TDC sensor wire , a bad connection or some shit could have be the cause of your problem .
Now another point , is it a phase one with the AEI above the turbo or is it a phase 2 with the AEI under the windscreen ?
If it is a phase 1 and since your AEI started to work again after it had received a shock ( apart from that , just relax when you work ) , the heat produced by the turbo could have damaged it . It happened once to me .
The only way to know if that is the cause is if it will break down again in a short period . That's the bad point .
If it is a phase one and if you want to remove it from above the turbo to under the wind screen , the only specific part you need is the phase 2 wire between the AEI and the distributor cap . It takes 30 minutes to modify .
Cheers
