Author Topic: gay campus  (Read 7426 times)
Re: gay campus
« Reply #15 on: 16:21, Wed 17 March 2010 »
The rear axle is held on with 4 large bolt and the rear shocks, easiest way to do it is find a donor car and take the axle complete with the brake bias valve and swap it onto the campus.
Another option to do is leave the campus axle on like i have, handles ok from what i've felt so far and the drum brakes work well enough too (no siezing calipers as usual).
5gttaron
Re: gay campus
« Reply #16 on: 19:04, Wed 17 March 2010 »
right last thing is how do i go about wirering up the dash loom???? and there is a pipe that comes off the carb on the right that doesnt go anywere it looks simular to the were the fuel line connets in
Re: gay campus
« Reply #17 on: 19:33, Wed 17 March 2010 »
Quote from: "5gttaron"
Do you mean drivers side or passenger side mate?
Are you using gt clocks on the dash? If so pull dash out and swap the loom over mate, you may have to change the chassis leg loom too if yours doesn't connect up correctly as some campus looms are different to turbo.
olie_r5
Re: gay campus
« Reply #18 on: 23:33, Tue 20 April 2010 »
as for dash wiring use a test light and find your lives and earths. You may need a pin removing tool and dash plugs so you can rewire. If i lived near ya would have lent you a hand being an auto electrician LOL
rover twin cam power \";)\"
gt alan
Re: gay campus
« Reply #19 on: 15:49, Wed 26 May 2010 »
can anyone confirm if the chassis leg looms need changing to the turbo ones, also the rear looms for lights and pump.
im half way through doing my conversion and dont want to scrap the gtt shell with them in it if i need them
oh my campus is a 95 and has efi if that helps
thanks
Re: gay campus
« Reply #20 on: 16:16, Wed 26 May 2010 »
I can't remember if you do or not need to change the chassis leg loom mate, best thing is to keep the gt one just incase.
Also the rear loom will be different abit different on the drivers side so worth keeping that from the gt shell too.
gt alan
Re: gay campus
« Reply #21 on: 16:45, Wed 26 May 2010 »
thanks mate
im gonna be keepin the campus tank too
Re: gay campus
« Reply #22 on: 17:09, Wed 26 May 2010 »
Quote from: "gt alan"
thanks mate
The tanks are identical on the outside, only the gt has a baffle in there.
You will need the gt pump though, sender unit is same on campus 1.4 and turbo so no need to swap that either
Re: gay campus
« Reply #23 on: 12:07, Fri 28 May 2010 »
Hondaman - out of interest, is your 5 a campus lookalike?
Just that I sold one a while back with a similar mileage on the clock. If it is - is it blue? :)
Re: gay campus
« Reply #24 on: 18:09, Mon 28 March 2011 »
if this thread is a list of things u need to change for the campus convertion i got 2 things 2 add to the list
rear windows are sealed closed on the campus but they still have the hole to bolt the hinges into they just have little covers over em
and the skirts all need to be riveted on some how
modfather
Re: gay campus
« Reply #25 on: 11:01, Wed 30 March 2011 »
i have done this conversion myself, i have uesd the original dash loom from the 1.4 gts, while using the gt clocks, all working fine.had to add a couple more relays ie fuel pump, also found that there is a bracket for a brake bias, i swapped all brakes,suspension torsion bar etc for gt items, had to change engine loom, driver side loom (inside the car) for the fuel pump
