Author Topic: engine goes out...what else to replace while out?  (Read 1450 times)
VintageSpeed
« on: 20:56, Sun 21 February 2010 »
Title sais it all  :mrgreen:
Since I'm going to take out engine/gearbox what do you suggest to replace for sure?
Clutch? timing belt? other stuff...?
thanks
Re: engine goes out...what else to replace while out?
« Reply #1 on: 11:40, Mon 22 February 2010 »
Quote from: "VintageSpeed"
thanks
Why's the engine coming out in the first place? is it a rebuild?
If the engine is coming out it is always worth replacing the clutch if it has not been done in sometime.
I would also look at the engine mounts whilst you are there to make sure all ok,
No timing belt on the C1j it merely has a timing chain, and an alt belt which is about £10 and takes nio more than 5 mins to replace but again worth doing
« Reply #2 on: 08:56, Thu 25 February 2010 »
Water pump may be worth a look, but be careful as some of the bolts like to sieze into the head sometimes & snap off :(
If you aren't splitiing the engine then don't worry about the timing chain, deffo do the clutch & maybe a lightened flywheel ?
As James said, maybe the mounts while you're there & check for oil leaks, if it looks like it's leaking from anywhere you may as well replace gaskets etc. easier when out, especially the timing chain cover & sump U seals !
VintageSpeed
« Reply #3 on: 13:19, Thu 25 February 2010 »
Should I replace the cluthc just in case?
Doesn't seem bad atm, but still...
Which should I get?
