well :lol: :lol: At some of the comments lol
Erm right well IIRC , when I did it ..... I cut the cables that run from the matrix to the control facia. (x2 of them) Just basicly to shorten them in (hien) sight! *spelling*
then I also cut the power supplys and earth and any other protruding wires then Extended them , with some good quality Electrical wire and then used some low thickness solder to rejoin the wires back onto the plug.
I then threaded the cables / plug through the exsisting gap left by the headunit and also pulled through the shortened silver adjuster cables and then carefully put them back into the correct posistion.
(Head unit Detail)
Almost the same to behonest as above , Cut the wires to extend them . threaded them up through the gap left by the heater control panel Inserted the cage (I used some silicone cellant to glue this in place not a hole tubes worth though :lol: :lol: two good lines worth)
Left to dry over night, clipped the power plug back into place then pushed back firmly into the cage hay prestoooooooo
Only thing that I never did was extend the Radio cable , but this is quite easy to be honest
Some ones more than likely got a much better way of doing it ! . but theres just a rough rough guide
