Author Topic: Quick question what the spark plug gap clearance on the GTT  (Read 1021 times)
« on: 15:12, Fri 19 February 2010 »
As per title needed asap no Haynes to hand as at work and going to have a look at the sparkies before I drive home tonight.
Cheers James
Re: Quick question what the spark plug gap clearance on the GTT
« Reply #2 on: 18:13, Fri 19 February 2010 »
:shock:  :shock:
Some one told me once upon a time it wasn't neccersary to gap the plugs on the 5GTT .....
oooooooooh Dear  :? What would this do ?
Rob@BYR
« Reply #3 on: 22:13, Fri 19 February 2010 »
Checking gaps is a good thing to do, if you have a high tune/ boost your spark can easily get blown out (if you can call it that) if to large a gap, normaly around peak torq areas this will occur, 0.7 is fine to run, i run .8 on my turbo civic...
