Author Topic: Identifying a stock wastegate setup  (Read 2732 times)
Speedbird
« on: 16:33, Mon 01 February 2010 »
Hello,
Is there a way to know if a wastegate setup has been altered to increase the boost and then switched back to original?
Thanks a lot
Re: Identifying a stock wastegate setup
« Reply #1 on: 17:39, Mon 01 February 2010 »
A way of telling if it has been played with to increae boost is the actuator arm will be shorter than standard.
« Reply #2 on: 21:29, Mon 01 February 2010 »
Just look for obvious spanner marks on the locknut, i'm sure standard actuator arms have a hole in them, the threads visable through that hole should be punched flat.
Speedbird
« Reply #3 on: 09:23, Mon 08 February 2010 »
OK thanks, I'll be carefull about that.
Andygordini
« Reply #4 on: 22:26, Sat 14 July 2012 »
On my 5 the waste gate has no pipes attached and a valve in place with a screamer pipe but I'm trying to find info on this valve due to it being diconnected please help or push me in the right direction :)
