Author Topic: turbo chatter ????  (Read 9173 times)
mucsmith
Re: turbo chatter ????
« Reply #15 on: 20:18, Fri 29 January 2010 »
pics or vid very much needed on my behalf  :oops:  :lol: cheers
« Reply #16 on: 20:20, Fri 29 January 2010 »
TIP - use a 3'' long peice of wooden broom handle and wedge it where the D/V goes ,
Then pull out the the vacum hose that fits into the front of the D/V , Use a bolt to wedge into the end of the silicone vacum pipe if your not 100% confident in removing the pipe work completely  , this will eliminate the D/V set up  [ just Remember to tuck it away some where its not going to either melt on something hot , or get stuck/ wedged in.
Then remove air box and fittings , attache the 90degree bend to the turbo cold side , then place the metal pipe into the bend then filter at the end! . yeah maybe a t2 will sound slightly different but still miles better !
hendyR5
« Reply #17 on: 20:25, Fri 29 January 2010 »
magic buddy thats me sorted!  8)  al see if a can get a decent filter and bend 2moro!!!
This is my first 5 so my knowledge is fairly limited shall we say lol
out of interest matt, how much did the 360 turbo set u back?
« Reply #18 on: 20:32, Fri 29 January 2010 »
I got it from Turbo technics cost me around 600 pounds if i can Remember rightly ,
Like everthing mate once you've messed around with some thing once or twice it suddenly becomes of seconed nature !
My knowledge was poor but i bought a haynes manual and that really helped me out , obviously not for things like this Lol's . We've all been there !
hendyR5
« Reply #19 on: 20:37, Fri 29 January 2010 »
True m8, av had a few problems with mine had it nearly a year!!!
the best and worst thing av ever done!!!! lol
this site is a gr8 help tho, am always on seeing what a can do next!!! lol
whats the 360 like? a bit ballistic a bet? a luv the T2 dnt get me wrong - when it kicks in it kicks in but always wanted something 'faster'  :lol:
mucsmith
« Reply #20 on: 20:38, Fri 29 January 2010 »
matt can you tell me if 30 offset wheels will fit plz !!! 15 " 7j !     or 6j 13" ats classics
« Reply #21 on: 20:41, Fri 29 January 2010 »
Am so sorry my main man I am as clueless as a slug when it comes to offsets .  :cry: Sorry matey!
hondaman
« Reply #22 on: 22:47, Thu 04 February 2010 »
basically your a mug if you WANT your turbo to chatter, its just about the worst thing to ever want for your turbo, yes it sounds good but if you actually imagine the forces that are involved to make a turbine wheel thats spinning at about 150krpms to stall instantly itl make you cringe....and then need a turbo rebuild
« Reply #23 on: 23:15, Thu 04 February 2010 »
:lol: I believe I've seen this topic argued on just about every forum Ive encounterd, My theory is, its the cars owners choice .  :wink:
hondaman
« Reply #24 on: 09:59, Fri 05 February 2010 »
yea i know but it makes me kinda cringe knowing that some one actually wants to damage there car but i suppose its a renault 5 and parts are silly cheap to repair em!
« Reply #25 on: 11:18, Fri 05 February 2010 »
The damage is questionable. The R5 didn't leave the factory with any bypass valves at all and many owners have not suffered any premature failures because of this.
As i mentioned in my other post most if not all modern turbo cars do have bypass valves, but this seems mainly in the interest of keeping the engine running smoothly rather then actual physical damage.
« Reply #26 on: 16:31, Fri 05 February 2010 »
Quote from: "hondaman"
Uh-oh, here it comes again  :roll:  :lol:
mucsmith
« Reply #27 on: 16:51, Fri 05 February 2010 »
guess im a mug then hondaman !!!!!!!!! renault 5 gtturbo.com ????  :P
Ruivar
« Reply #28 on: 16:54, Fri 05 February 2010 »
Honestly, I do not have the greatest knowledge on turbos, but I know that the WRC rally cars' turbos do chatter. I've heard it. And it is also mentioned earlier in this thread... So why would they race with turbo chatter, if the chatter is potentially damaging? They would know what's best, I reckon??
PS. I too am currently thinking about removing my dumpvalve :D
Cheers...
What happens when you blow on fire?
« Reply #29 on: 17:22, Fri 05 February 2010 »
Quote from: "mucsmith"
Big time!  :wink:  :lol:
