Author Topic: squeeky heater fan repair (cheap and easy)  (Read 2491 times)
mucsmith
« on: 17:11, Thu 31 December 2009 »
fixing my squeeky and anoying heater fan the easy and cheap way !! first of all use a small drill bit 3-6mm and drill about 10mm away from the main shaft(the plastic fan under the bonnet as you look at it) but drill in at an angle so when youve reached the other side its somewhere near the main shaft !! then simply spray wd40 down the hole and bingo job done peace and quiet !! hope this makes sense it does work i promise!!!!!!!!!!!!
