Author Topic: my 1991 R5 GT Turbo  (Read 69276 times)
bluntyr5gtt
Re: my new R5 GT Turbo
« Reply #90 on: 15:10, Thu 20 January 2011 »
thats cool no probs at all
yes its t2 but the biggest t2 rear housing you can get i know turboted off the rtoc used a turbo very similar to mine and had good results, am not really a figure chaser though as long as it goes well and is set up right then ill be happy :)
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Ramair Induction Kit
cosworth 2wd Intercooler
Lowered 50mm
bluntyr5gtt
« Reply #91 on: 15:44, Thu 20 January 2011 »
pics of my new carb that iv repainted with chrome enamel
before
after
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
Chadster
« Reply #92 on: 19:07, Thu 20 January 2011 »
what suspension you got on there as its sitting sweet like that
« Reply #93 on: 19:33, Thu 20 January 2011 »
You'll be fine once you get it set up.
You can take the lump out leaving the box in, do the clutch, cam etc once it's out  :wink:
bluntyr5gtt
« Reply #94 on: 06:48, Fri 21 January 2011 »
Quote from: "Chadster"
im pretty sure its spax suspension mate
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
« Reply #95 on: 17:28, Wed 26 January 2011 »
new turbo
spec as follows
cosworth comp housing, pulsar t28 wheel, .63 t2 ex housing
fully rebuilt,balanced, 360 bearing shaft re grinded and bead blasted to look like new
i can now get any turbo done at really good prices from full rebuilds to hybrids like the above just give me a shout via pm
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
« Reply #96 on: 13:52, Sun 27 February 2011 »
bit of an update
cars now at automedics in stoke with justin ex ep motorsport tuner getting all the work done :) also a bit of good news is that the clutch was fine it just needed a new cable and pedal.
oh and iv also bought a set of morette twin headlights purely so i can use them to feed more air into the engine bay along with the gtt bumper vent. i should have the car back by weds evening i cant bloody wait as well.
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
fordy
« Reply #97 on: 21:52, Tue 16 August 2011 »
blunty
hows the t28/t2 performing? have you had it power run'd at all? looking at making the same out of a t28 200sx turbo and a t2 5gtt turbo   :mrgreen:
bluntyr5gtt
« Reply #98 on: 21:59, Tue 16 August 2011 »
works really well mate very good set up really strong , what set up are you going for? iv seen something that u might use a t28.64 ex housing, dont do that its way too laggy biggest ex housing you want is t25.49.
my set up is cossie comp housing, pulsar t28 comp wheel, .63 t2 ex housing with t2 wheel
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
fordy
« Reply #99 on: 23:21, Tue 16 August 2011 »
i'm really not sure what i want to do yet so looking around for facts n figures since i have a 200sx t28 and a t2 sitting
Seem to be doing alot of track stuff lately and dont wanna be ragging it for 20mins a time to keep within the power band but i want a bit more poke
bluntyr5gtt
« Reply #100 on: 05:56, Wed 17 August 2011 »
tbh if your on a track keeping it in the power band shouldnt be a problem, i cant see why you wont be able use the t28 front and mate it to the t2 rear am sure bb tuning used do something similar
if your after someone to build you the turbo up then give me a shout pal
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
« Reply #101 on: 14:37, Wed 17 August 2011 »
been a real long time since i updated this thread alot of things have been done etc first of all ill add some pics for you all :)
mine and bros car together after last dyno day in july bros car made 180bhp/210lb/ft i didnt run my car.
head before
head after
after using poorboys black hole and dodo juice supernatural hybrid it rained literally 2 mins after i had finished
how the engine bay looks now
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
« Reply #102 on: 14:46, Wed 17 August 2011 »
also added a 285mm big brake conversion (best mod iv done )
and bought a tubular manifold as part of the group buy on rtoc
alot of people asked me to comment if i noticed any difference in power or spool up etc with this manifold i cant honestly comment on power as i had alot of headwork done as well as inlet ported at same time. but i can say spool up has not improved at all.
i now run my car at 21psi on the t28/t2 which im really happy with still not got a power figure yet but i will soon so please bear with me :).
current carb spec is as follows
standard venturi
120 main
0.9 air corrector
2mm needle valve
1.3 2nd stage
fuelling is pretty much bang on really strong even at high revs in 4th/5th gear. i am on the lookout for a different induction kit preferably a decent size cotton green or ram air etc
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
« Reply #103 on: 15:20, Wed 17 August 2011 »
car is looking great blunty  8)
like I said via pm on rtoc, keep us all posted with your rr figures. Really interested in what your turbo can do  :mrgreen:
bluntyr5gtt
« Reply #104 on: 15:23, Wed 17 August 2011 »
thanks alot mate :) much appreciated
i was hoping get it on dyno this weekend but it looks like am working on saturday now so thats scuppered that idea.
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
