Author Topic: my 1991 R5 GT Turbo  (Read 70034 times)
bluntyr5gtt
Re: my new R5 GT Turbo
« Reply #75 on: 06:04, Sun 31 January 2010 »
t28 idea and 285 cam is out the window for now got alot more important things to spend my money on in the next 2-3 months, the car is going into gt motorsport on the 8th feb to have all the new bits fitted along with the ported head , ktec downpipe and gt motorsport machined/enlarged turbo elbow
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Ramair Induction Kit
cosworth 2wd Intercooler
Lowered 50mm
hondaman
« Reply #76 on: 16:41, Fri 05 February 2010 »
nice little project there mate, so did the previous owner not bother with a skim or something? what a pikey if he didnt! tbh £180 is so cheap man thats why i love these little old cars co much, if it were a honda that would probably be gettin on for £400
bluntyr5gtt
« Reply #77 on: 16:48, Fri 05 February 2010 »
god knows mate i could give him a few slaps tho, tbh i got quoted 350-400 by most places do mine but im good mates with mark at gt motorsport :)
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
mucsmith
« Reply #78 on: 16:56, Fri 05 February 2010 »
well its not a honda is it !!!! and if it was who cares  :lol:
bluntyr5gtt
« Reply #79 on: 05:24, Fri 12 February 2010 »
took a few more pics of my car last weekend this was just after id topped the ag high def wax up on it (light was not the best)
also got a pic of the ported/bored turbo elbow that mark at gt motorsport is doing me my car is up there now and should have it back today iv had all the fuelling set up by wideband he tells me it was running very lean so good job its being set up ill let you know what alterations he made to the carb etc when i speak to mark 2nite.
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
« Reply #80 on: 08:06, Sat 15 January 2011 »
bloody hell guys its been ages since i been on here and updated this thread
so ill cut to the chase and tell you whats been bought and going on
bought the following
universal fmic intercooler kit
aem wideband kit
new rad hoses
header tank to heater matrix hose Sfs
cat cams 285 cam, vernier and springs
carb jetted to run 20psi
rear strut brace
3 plasma gauges boost,oil pressure and oil temp
the car has been faultless even been using it over these winter months ian nixon set it me up at 16psi and stuck new pistons liners and gaskets in there for me as they had seen better times.
taking the car up to gt motorsport this coming friday to get the fmic, wideband kit and plasma gauges fitted, will also stick the rad and heater matrix hoses on while am there. all being well next month will get my rebuilt t25/t2.63 with t28 wheel and cosworth comp housing back and fitted along with the carb and 285 cam
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
« Reply #81 on: 10:09, Sat 15 January 2011 »
Should be making good power once it's set up :)
bluntyr5gtt
« Reply #82 on: 16:34, Sat 15 January 2011 »
yeah i reckon so mate
my bloody clutch looks like its giving up so thanks to steveL i will have a replacement once i pay for it next thurs am also hoping get a l/b flywheel on there
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
« Reply #83 on: 15:25, Wed 19 January 2011 »
quick pic from today been using car for work this week
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
meum
« Reply #84 on: 18:24, Wed 19 January 2011 »
Very nice this gtt !! 8)
bluntyr5gtt
« Reply #85 on: 18:44, Wed 19 January 2011 »
thanks mate :)
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
« Reply #86 on: 11:40, Thu 20 January 2011 »
iv decided not get the work done on my car this month due to the clutch deciding its had enough and becoming virtually impossible to get into 1st or reverse lol
so iv already bought an uprated clutch from steveL and am looking into a l/b flywheel courtesy of big jim racing, iv re booked my car in for the 16th of next month so i can have all the following done
fit new clutch and lightweight flywheel
fit new rebuilt t25/t2 .63 turbo (t28 pulsar wheel and cosworth comp housing)
fit fmic
fit 285 cam,vernier and springs
fit aem wideband kit and plasma gauges
fit new rebuilt carb jetted for 20psi and check fuelling is spot on
should make for a total different car once done
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
« Reply #87 on: 12:25, Thu 20 January 2011 »
Looking good matey, with the extra bits it will be very different when you get it back on the road.  The AEM AFR kit is a very good matey I use the same one and can't fault it.
Are you building it yourself or is Big Jim doing the work for you?
bluntyr5gtt
« Reply #88 on: 12:47, Thu 20 January 2011 »
big jim is just doing the l/b flywheel for me then am taking it up to gt motorsport to get the work done, quick question is the clutch and flywheel an engine out job ? if so it makes it easier fit the cam at same time :)
yeah i reckon ill be rather impressed when its all set up 200bhp maybe?? we will wait and see
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
« Reply #89 on: 15:05, Thu 20 January 2011 »
Yeah engine out matey, all though you can do them in the car it is a right bugger to do :)
200bhp Not sure on that turbo at it's part T2 I assume the rear side so that will be the restrictive part.
