Welcome,
Guest
. Please
login
or
register
01:07, Wed 10 August 2022
Home
Help
Search
Login
Register
RENAULT5GTTURBO.COM
GENERAL
Your cars
my 1991 R5 GT Turbo
« previous
next »
Print
Pages:
1
3
4
5
6
7
11
Author
Topic: my 1991 R5 GT Turbo (Read 69954 times)
bluntyr5gtt
200BHP Senior Member
Re: my new R5 GT Turbo
Reply #60 on:
08:05, Mon 18 January 2010 »
i have wiped the cap off twice tho and its come back again ?? the oil on the dip stick looked normal to me
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Ramair Induction Kit
cosworth 2wd Intercooler
Lowered 50mm
baby blue r5 gtt
170BHP Member
Reply #61 on:
09:21, Mon 18 January 2010 »
prob just condensation from been sat about, even if you wiped it ,
maybe a bit of condensation on the underside of the rocker cover, keep a keen eye on temps and oil etc and just see what comes about
Logged
Global Moderator
Reply #62 on:
10:19, Mon 18 January 2010 »
I wouldn't worry about it to be honest.
Time it worry is when either the dipstick is covered in mayonaise or your rear view mirror is filled with smoke.
As a precaution just keep your eye on oil/coolant levels and coolant temperature.
Logged
bluntyr5gtt
Reply #63 on:
11:54, Mon 18 January 2010 »
it is the head pal coolant is dropping big time and iv fount the oil leak peeing out the rocker cover looks like the last owner did a d.i.y job on the head, just had a price to do it £180
plus iv ordered a top rad hose thermostat
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
Global Moderator
Reply #64 on:
13:34, Mon 18 January 2010 »
Unlucky.
Rocker covers leaking isn't uncommon though, sometime they leak past the 3 nuts if the washers have not been replaced.
Also, if the rocker cover is overtightened the sides can bow outwards, so it doesn't seal very well at all onto the cylinder head.
Logged
baby blue r5 gtt
170BHP Member
Reply #65 on:
19:17, Mon 18 January 2010 »
twat eh, thought it was too good to be true at the price you bought it, least its not going to cost much to fix
Logged
bluntyr5gtt
Reply #66 on:
19:24, Mon 18 January 2010 »
well it is going cost more now as iv had a cunning plan which involves getting the head ported and a piper 285 cam kit
also goin renew the plugs/leads, fan belt, timing chain and tensioner
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
baby blue r5 gtt
170BHP Member
Reply #67 on:
20:31, Mon 18 January 2010 »
if a jobs worth doing and all that :lol:
Logged
bluntyr5gtt
Reply #68 on:
05:48, Tue 19 January 2010 »
well im going go to town with the car now i was going to get a 285 cam and get the head ported but funds wont allow and i think its best to get it running properly and healthy, so am getting all the basics as i have the feeling this car has been a bit neglected its getting the following
new group a head gasket set
new plugs
8mm lucas ht leads
new dizzy cap and rotor arm
new fuel filter
uprated fuel pump
new fan belt
new timing chain and tensioner
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
Reply #69 on:
05:58, Thu 21 January 2010 »
UPDATE
right the engine is going to be taking a different route now instead of me getting the head done straight away, im being patient and im currently negotiating a nice fully ported head with uprated springs from CGB Motorsport and to compliment this ill be adding a 285 cam and vernier iv also got my eyes on a front grill mounted intercooler which will then allow me to position the air filter in a much better place. now i know ill get slated for this over on the RTOC but im also toying with the idea of getting a tubular manifold and doing back to back tests and seeing just what is the diff if any would be interesting to know for sure.
All the above added to the 2.5" downpipe and GT Motorsport turbo elbow should get all the air/gass flow to its maximum which can only be a good thing ill prob stick the hybrid t25/t2 turbo i have on at the same time as well run at about 18psi
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
bluntyr5gtt
Reply #70 on:
07:55, Sun 24 January 2010 »
my new investment thought it was rude not too as id reckon my cylinder head wont be much good as its at least gone twice before plus this will go with the spec im going for
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
just watching and bidding on a t28 off a 200sx s14 now all ill have to do is change the rear housing to a .49 as the .64 will make it too much of a lag monster, with the .49 i believe ill be getting full 22psi boost at 4k
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
Global Moderator
Reply #71 on:
11:36, Sun 24 January 2010 »
Interesting, the area around the base of the valve springs is clearly very different.
Logged
bluntyr5gtt
Reply #72 on:
12:13, Sun 24 January 2010 »
yeah it looks a better design to me
my other new investment
Nissan 200SX T28 turbo going to get a .49 rear housing on it to replace the .64
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
Global Moderator
Reply #73 on:
14:15, Sun 24 January 2010 »
You will need adaptors for the compressor housing. See how the pipework is bolted on instead of using just jubilee clips.
They should be easy enough to find.
Logged
bluntyr5gtt
Reply #74 on:
15:40, Mon 25 January 2010 »
ok mate ill get that sorted next months purchases will be piper 285 cam and vernier
Logged
ported head
bjr downpipe/elbow
tubular manifold
fully rejetted carb
Lowered 50mm
Print
Pages:
1
3
4
5
6
7
11
« previous
next »
RENAULT5GTTURBO.COM
GENERAL
Your cars
my 1991 R5 GT Turbo
