Thanx for all the tips Guys,
Yep, the first thing i did was check for leaks but nothing.
Turbo is working fine.
The only reason i can see that it is on a lowly 5 psi boost is that there is a in car boost controller however it has not been connected up.....so maybe somebody has played with the actuator and forgot to reset it back.
Having the items i listed above i should be safe in cranking it up to say 14 psi dont you think?
How does one know if it has an uprated head gasket is the big mystery. Mmmmmm.
