Author Topic: think its gone  (Read 2061 times)
DanielSon-gtt
think its gone
« on: 13:37, Tue 23 June 2009 »
i went to top up my water and there was a shed load of oil in the exspansion tank but i only recently done the head gasket about 6months ago but most of that time its been sat still what else could it bee
Go Boost Or Go Home
« Reply #1 on: 14:13, Tue 23 June 2009 »
Didn't you have this problem not so long ago? Or was that someone else.
stoneboy2k3
« Reply #2 on: 14:20, Tue 23 June 2009 »
I got the same problem atm, I think mines dwn 2 a leak between oil cooler and rad as no water in filler cap or sump
« Reply #3 on: 14:24, Tue 23 June 2009 »
oil in the water is usually the oil cooler splitting & mixing with the water in the rad... or a cracked head....
DanielSon-gtt
« Reply #4 on: 14:35, Tue 23 June 2009 »
I did have this problem a little while ago its come back.
I have a external oil cooler running so its not mixing in the rad and when i had the head skimmed before they checked it over and didnt find anythink wrong with it.
Go Boost Or Go Home
itzik
« Reply #5 on: 15:10, Tue 23 June 2009 »
did you clean the cooling system after you changed the Head gasket?
stoneboy2k3
« Reply #6 on: 15:53, Tue 23 June 2009 »
Sounds like u have cracked the head to me fella
DanielSon-gtt
« Reply #7 on: 16:45, Tue 23 June 2009 »
yea i had the engine out and everythink was striped so basically it was a fresh start with all fluid how would i pinpoint a cracked head
Go Boost Or Go Home
« Reply #8 on: 18:02, Tue 23 June 2009 »
You won't really as it will open up when warm or under pressure :(
Get another head from somewhere & hope it goes away.
Rob@BYR
« Reply #9 on: 19:31, Tue 23 June 2009 »
Yep could well be head, i remember a few years back on my old GT i had this problem, i changed the gasket twice, also pressured the head with no joy, swaped the rad, the lot.... i then re checked the head but with alot of heat and the found the bugger... :)
« Reply #10 on: 22:19, Tue 23 June 2009 »
i had the same problem with a cracked head but are u definetly sure its not just shit left over. wen my head cracked every part of the cooling system was filled with thick horrible gunk. i flushed it countless times, ran it thru with non bio washing poweder an still even now 6 months later i still get a slight film of oil in my expansion tank
DanielSon-gtt
« Reply #11 on: 23:30, Tue 23 June 2009 »
its definatly not left over from last time as ive flushed it a number of times damm cracked head then unless the headgasket has gone again ill just buy a new head and a new gasket :(
Go Boost Or Go Home
« Reply #12 on: 00:38, Wed 24 June 2009 »
ffs sorry for you danny boy, this is else a reason am glad my 5s going, i just want an easy life lol
DanielSon-gtt
« Reply #13 on: 11:21, Wed 24 June 2009 »
thats what its all about tho ritee  :lol:
Go Boost Or Go Home
stoneboy2k3
« Reply #14 on: 11:25, Wed 24 June 2009 »
Yeah rebuild em @ least 4 times a year lol
