Author Topic: engine swap in my astra o4 plate van  (Read 5891 times)
dave r5
« on: 09:50, Fri 12 June 2009 »
ive herd that a 2.2 turbo deisle  will fit strait in
but dont know from wich car  any advice
renault shell, custom cage, no dash, volvo engine, nissan turbo, apexi boost controler, ksm re-wire, persision automotive down pipe, dta engine management to come.  175 BHP 220 LB/FT torque
« Reply #1 on: 10:52, Fri 12 June 2009 »
Vectra most likely i would of thought.
Most Vauxhall engines you can swap about quite easilly from what i've read.
« Reply #2 on: 12:24, Fri 12 June 2009 »
have you seen the prices of the c20 let lumps ?, Still going for silly money.
dave r5
« Reply #3 on: 12:41, Fri 12 June 2009 »
wats a c20 let ??
sory to sound thick lol
DanielSon-gtt
« Reply #4 on: 12:55, Fri 12 June 2009 »
2litre redtop jobby
Go Boost Or Go Home
dave r5
« Reply #5 on: 14:09, Fri 12 June 2009 »
ohh  sos  i just know um as red tops lol
wat sorta price u rekon im looking at for a 2.2 deisle lump?
« Reply #6 on: 19:17, Fri 12 June 2009 »
couple of hundred probs lol
R4223R
« Reply #7 on: 21:58, Fri 12 June 2009 »
put a vectra b gsi msd engine in the2.5 24v v6 model
dave r5
« Reply #8 on: 12:05, Sat 13 June 2009 »
will it fit?
do u have 1?
R4223R
« Reply #9 on: 20:38, Sat 20 June 2009 »
I had a vectra gsi msd and i was planning on doing the same thing it will fit and the dash and door cards etc..
also join migweb its a vauxhall owners web site you will get loads of help and info on there.
scottyp1989
« Reply #10 on: 16:00, Tue 13 October 2009 »
the redtop and v6 lumps are a rite pain to do in a mk4 astra but if you are going for a disel out of a vectra you will need to change the box unless you want to be makeing gearbox mounts
baby blue r5 gtt
« Reply #11 on: 16:47, Tue 13 October 2009 »
c20xe = 2.0 16v n/a
c20let= 2.0 16v f/i
beast engine to fit a mk4 astra would be a z series engine as put in the mk4 ie
z20xe = 2.0 16v n/a
z20let = 2.0 16v f/i
there modern engines and were relaesed to co inside with the mk4's launch so will be a straight swap mount wise although wiring looms will need swapping and fuel tank if yours is a diesel now,
the older redtop (so called by the red plug cover with 90 degree bend in and also called c20xe) does fit although this engines was originally fitted to the astra gte 16v and early mk3 gsi's, calibras and cavalier gsi's can be fitted although not quite as easily but the engine is more readily available but most are 100k plus nowadays
baby blue r5 gtt
« Reply #12 on: 16:50, Tue 13 October 2009 »
Quote from: "R4223R"
never heard that the vectra dash and door cards fit? i'm assuming you mean with lots of work
