Author Topic: Ratlook 5 TD04 Project  (Read 50751 times)
Re: Ratlook 5 TD04 Project
« Reply #180 on: 17:20, Sun 04 July 2010 »
Awesome, good job buddy
« Reply #181 on: 00:06, Mon 05 July 2010 »
I'll put them up after work tomorrow for you  :wink:
Looks like another cracking job  8)
« Reply #182 on: 15:09, Mon 05 July 2010 »
Le engine......... IN  :D
« Reply #183 on: 15:29, Mon 05 July 2010 »
Top work Mark as always, out of interest what is the pubaru turbo like on the ickle gtt lump?
« Reply #184 on: 16:45, Mon 05 July 2010 »
Quote from: "James5"
I'll let you know mate once i've fitted a new actuator and bracket, it'll be set to 16psi.
« Reply #185 on: 16:50, Mon 05 July 2010 »
We were wondering, if the actuator wasnt weak, but the bracket was moving about, as it was only on one bolt.
Whats with the yellow water pump :D
I spent hours getting all yellow off that car, it was everywhere :D
« Reply #186 on: 22:32, Mon 05 July 2010 »
Quote from: "sparkysparks"
I had abit of yellow paint left so thought sod it, brighten the engine bay up abit. I still got few little bits i want to tidy up but so far thats how its staying now.
I went for yellow as it was the only boost pipes i could get, also goes with the radioactive fuel filler cap!  :lol:  :D
DanielSon-gtt
« Reply #187 on: 22:38, Mon 05 July 2010 »
Get some fresh jubilies on them boost pipes that's the only thing letting it down good work
Go Boost Or Go Home
« Reply #188 on: 03:25, Tue 06 July 2010 »
Glad you kept that on :D
« Reply #189 on: 23:00, Fri 09 July 2010 »
Ok guys, its been a while. Ive been a bit lazy on posting and helping out on the site. Thought id give you all an update on the lil beasty
The girlfriend hates me car with a vengance! She has no real reason other than its too fast and ugly.
She is wrong!
But, shes a goodun so i got a bonnet that wasn't rusty, so she can stand it a bit more, nice aint I ;)
Also got a campus grill (i prefer it to the turbo anyway, looks smoother and more discreet).
Before
After
Ive still got some rat in me though so i added this as my personal touch.
I did have another engine problem a while back and its not been on the road since. (fixed but not had the funds to get it OTR)
My headgasket had gone. When i had the last problem of the piston falling apart i stupidly re-used the HG as we only did a compression test on it. That was the root of my problems i think. From then on it was using coolant every now and then.
It got really bad and i had to limp it home 70 miles from uni.
That didn't go to plan...
It popped on the M1 and i was left waiting for recovery on the side of the motorway where another motorway had just joined. (yes a very dangerous spot :D)
Found this when i took it all apart.
Very conveniently for me, SCRATCHER was replacing his pistons at the time and i bought his used pistons, liners and rings off him.
Engine all back together. I bought another carb, took it all apart, cleaned it all up, put it on.
Car would start but die straight after.
Turned out i had some goo in the main jet.
All cleaned up AGAIN, she purrs like a kitten now :D and not a drop of smoke from the exhaust.
More to come...
Did you find out what cause the piston to do this??
« Reply #190 on: 23:36, Fri 09 July 2010 »
Oil starvation?
« Reply #191 on: 02:31, Sat 10 July 2010 »
yeah i think it was that the oil had mixed with the water to a point where it wasnt lubricating it. nice eh, ive still got that one
« Reply #192 on: 10:55, Sat 10 July 2010 »
I am not to sure what mine is although I have no oil and coolant mix, I did have some low oil pressure and was running very low on fuel in the tank at the time and was co,ming around a long bend hard in the 5
« Reply #193 on: 11:26, Sat 10 July 2010 »
The scoring on the piston will be down to running lean causing the piston to get hot and expand, not lack of lubrication.
« Reply #194 on: 12:30, Sat 10 July 2010 »
oh ok fair enough. Still a mess though.
