Author Topic: Few problems  (Read 2856 times)
Theros
Few problems
« on: 20:56, Sat 06 June 2009 »
Ok...
After long time I am here :) ...now I have problems with wires and hoses.
Could you give information about C1J engine wiring...please be as specific as possible...I went to refit wires and hoses to my R11 Turbo. I used tape and pencil to mark everything before I removed wires, but after couple of months I couldnt find out what is going and where :( ...
Then hoses...how I should place hoses to fuel pressure regulator and which hose goes and where (I have twin choke weber in my car).
Then twin choke weber carb...I have to place all hoses there....which one goes and where?
Then LC-1 wideband questions...
I connected ground and power wires, but then there are blue and violet wires too...where I should connect those???
Theros
« Reply #1 on: 21:25, Mon 08 June 2009 »
nobody knows? Shame... :(
Theros
« Reply #2 on: 18:39, Wed 10 June 2009 »
Any directions where I might find information?
« Reply #3 on: 21:24, Wed 10 June 2009 »
if u get some pics up of the wires an conectors ur havin problems with im sure between us all we can tell u wot goes where, as for the twin choke webber carb i cudnt tell u.
this shud help with the lc-1 tho
http://www.innovatemotorsports.com/support.php
Theros
« Reply #4 on: 12:20, Thu 11 June 2009 »
Yup. I asked from there and no help this far.
I will post some pictures today from wires.
« Reply #5 on: 12:23, Thu 11 June 2009 »
this is wot i was pointing u in the direction of
http://www.innovatemotorsports.com/supp ... Manual.pdf
Theros
« Reply #6 on: 09:00, Fri 12 June 2009 »
Here is pictures from wires. Actually wires that are not connected need some explanation.
Theros
« Reply #7 on: 08:34, Sat 13 June 2009 »
Did you recognize any connector or wire?
« Reply #8 on: 09:32, Sat 13 June 2009 »
only in the third picture down, theres a the head light connector hangin over wing. Is it all back together yet? because wot happens with me after i remove an engine, i look at a think oh fuk wot goes where but once i get all the bits back on it all comes back
Theros
« Reply #9 on: 08:36, Sun 14 June 2009 »
Thanks about that... I try to find a place :) ...still there are some question marks.  :)  :oops:
