Author Topic: new thermostat  (Read 1685 times)
new thermostat
« on: 21:20, Mon 25 May 2009 »
alright guys, i brought a new thermostat the other day, my cars never had one, so im not sure which way its meant to sit
also im not sure it works, ive put in water with boiling water, and cold water, but there's no noticeable difference, so does it open with the push of water when its in the pipe ????
thanks  :D
« Reply #1 on: 21:32, Mon 25 May 2009 »
mines been taken away its something id like to put back , so am interested to know to.
« Reply #2 on: 00:48, Tue 26 May 2009 »
The 'pointy bit' faces the water pump.
It should open in boiling water, they don't open up much but you should see light around it.
r5gttraider
« Reply #3 on: 01:21, Tue 26 May 2009 »
well depends if you have a normal or low temp one and also could be stuck, to unstick it slowly heat the copper part over a flame from the stove or a heat gun, it should slowly open, but if it dosnt work at 90*c again then its defently knacered but for £7.50 for a low temp one its hardly worth taking a chance
as the fan may run but a stuck thermostat will kill your enigne
thus why i dont run one,one less thing to worry about, and the thermostat will spend its life open 99% of the time on a 5 turbo in the summer, when colder weatehr arrives ill put it back in, but the turbo keeps things warm in the colling system via the water cooled part and the oil cooler in the rad
