Author Topic: t25 fitment update/help needed....  (Read 4009 times)
mgree10
« on: 09:16, Fri 22 May 2009 »
Hi All,more help needed please....got the T25 modified and fitted,changed nothing else,standard airbox and carb setup,still rnning standard boost...when the car is warmed up starts to blow white smoke on deceleration/accelleration,fitting a alloy intercooler feed the airbox with pipe from frong grill?what have i done wrong,what else do i need to change?...thanks in anticipaion...m
« Reply #1 on: 10:01, Fri 22 May 2009 »
hey mate i take it it has just done this since you fitted the turbo is it a second hand one?white smoke =water blue smoke is oil so im asumming the head gasket aint blown probably seals gone in your turbo,i would remove turbo elbow and check that side for signs of oil and water coming out of the turbo,hope this helps
« Reply #2 on: 12:08, Fri 22 May 2009 »
When the oil seals in a turbo have failed it does look more white then blue, especially when your viewing it in the rear view mirror.
Pull the turbo elbow off, if it's oil and it's quite bad it will be full of black sticky mess.
« Reply #3 on: 13:00, Fri 22 May 2009 »
yeh ash is right there will be an oily resedue at the elbow
mgree10
« Reply #4 on: 13:00, Fri 22 May 2009 »
gents,turbo off,seems ok no mess?increase in backpressure and heat been told possibly oil stem seals?cars stood for a while and dosent get loads of miles now,bought some conditioner and going to give it a go...your thoughts...m
« Reply #5 on: 14:16, Sat 23 May 2009 »
I run without valve stem oil seals, for some reason they wont stay where i put them on my head.
It shouldn't smoke to bad if it's those, mine only puffs out the odd bit of oil on a hot start.
Tommo
« Reply #6 on: 18:15, Tue 09 June 2009 »
Worn Valve guides will let more through.
« Reply #7 on: 18:25, Tue 09 June 2009 »
did you bleed the oil from the turbo oil fee pipe before you started the car up?? ??
mgree10
« Reply #8 on: 09:34, Wed 10 June 2009 »
all,update...defo the seals in the turbo,got me hands on another,coz the car has had the work done to fit the origional t25 should be sorted in no time.....cheers again,mark
« Reply #9 on: 12:25, Wed 10 June 2009 »
head work to fit the t25 , I dont understand ? My t25 stage 3 just bolted on like the standerd T2
mgree10
« Reply #10 on: 12:37, Wed 10 June 2009 »
im a complete novice mate...enjoying the challenge though...the t25 came off a rover 220,so to me modifying even an oil drain was something new,oil feed wasnt long enough had to get new one made,even turning housings around and fitting/setting up actuator were all new...loving it,disapointed when i got the smoke though....mark
« Reply #11 on: 13:48, Wed 10 June 2009 »
oh you went for the Rover T25 , sorry I thought you ment something else
