So i looked at another 5 today and had a good poke around the underneath etc. basically there was some pretty bad rust around the boot window, couple of blemishes on the front of bonnet and the rubber around the front windscreen does not meet in the middle at the bottom meaning there is some rust gathering there. With the boot i am thinking that this could be replaced, bonnet tidied up. the thing is the windscreen rust does not look too far gone yet, how easy is it to sort rust out? i am guessing i would have to remove the glass and rubber. can quite a lot of rust be fixed without welding?? looking underneath you could tell it had been undersealed and looked, felt solid. right i gave the sills a good pull and push and they felt solid although had a fair bit of surface rust but did not have big lumps coming free etc, so is this ok or if they have a fairly good coating of brown rust should it be avoided? along the very end of the drivers door it is starting to rust and bubble, looks just like the end where mayber catches on closing. rest of bodywork looks good for age (apart from dent in drivers door), really solid around fuel cap etc.
So at what point do you guys walk away from rust? like i said it wasnt just falling off! i fully understand it is an old car but i do not want to have welding to do and want it to be useable and i think the price reflects the condition, lets just say its not up for thousands!!
