Author Topic: Quarter Mile times.  (Read 19336 times)
Quarter Mile times.
« on: 09:18, Sat 25 April 2009 »
Quarter mile times here, PM a mod or LEE to add a time in, times from slips only will be added so you need to send a pic of the slip as proof !!
Also add a small spec list of turbo,intercooler, use of nos/slicks etc. You can send bhp figures as well if you like, i'll start with my old car from last year.
11 sec GT Turbo's
Rob BYR 11.97 @ 120 -- T28, 285 cam, FMIC, drag tyres,23psi manifold, nos 25hp
12 sec GT Turbo's
Marky Mark 12.3 @ 111mph -- VNT, MSM cam, FMIC, Drag tyres, 20psi
Marky Mark (campus) 12.65@108.21mph -- T28, 21psi, 285 cam, fmic, MH slicks, clio 16v gearbox
Steve L 12.78 @ 108.8 -- T25,285 cam, FMIC, drag tyres, 24psi manifold.
Brigsy (extra van) 12.8@106 -- T28, 20lb boost, piper 285, fmic, mh 22" slicks.
13 sec GT Turbo's
scotty b  13.3 @101mph in mine at the pod, street tyres, 15 psi, re-jetted carb, std engine and double cap intercooler.
rs250nut 13.4 -- Gt2554r with .49 hot side, .42 t3 compressor, 260 cam, fmic, 21psi, modded carb, road tyres.
14 sec GT Turbo's
Tim B 14.6 in my extra van at Shakespeare raceway 2007. Std engine @ 15 psi on a T2. Toyo R888 tires.
dave r5 14.83 @99 14psi at north weald, test an tune .part worn tyres . volvo engine. fmic .
15 sec GT Turbo's
dikky 15.4 @ 90 at santa pod. double cap intercooler, stainless exhaust, rejetted carb 13psi boost
16 sec GT Turbo's
Other Renault/non Renault
cliolord.......Clio mk1 2.0 16v 0Psi - 13.28 @ 108.89mph
« Reply #1 on: 08:18, Thu 04 June 2009 »
I've opened this so people can add times, then I'll update the table..
I've also added a non renualt section.
dave r5
« Reply #2 on: 17:16, Wed 10 June 2009 »
dave r5 13.97@ 97mph 14psi   at north weald, test an tune  .part worn tyres . volvo engine.  fmic .
renault shell, custom cage, no dash, volvo engine, nissan turbo, apexi boost controler, ksm re-wire, persision automotive down pipe, dta engine management to come.  175 BHP 220 LB/FT torque
dikky
« Reply #3 on: 17:12, Fri 12 June 2009 »
if there aint no rust it aint worth drivin!!
dave r5
« Reply #4 on: 11:09, Wed 17 June 2009 »
i have a confesion
ive entered the wron time buy mistake
that time was ment to be  14.97
as i was at north weild agen this sunday an managed to run 14.83 @99
wich is an improvement
but am strugling to get her of the line  quikly
wat do ppl launch at wen doing a quater mile ???
« Reply #5 on: 16:24, Wed 17 June 2009 »
I used to rev the car to about 5500 & either dump the clutch or feed it in till it bites & then dump the rest if you get what I mean, as soon as you get grip, floor it basically..
But decent tyres help ALOT !!
Low profiles are no good really as the tend to tramp & not flex to aid grip.
dave r5
« Reply #6 on: 12:23, Thu 18 June 2009 »
ineed a set of standard discs an a set of 14's realy  dont i
« Reply #7 on: 14:47, Thu 18 June 2009 »
or 15's with a taller tyre wall, then let them down a bit on track, something bigger than a 45 profile, but then you run the risk of the tyre rubbing on the shocks or kit :(
13's with a 55 or 60 prfile would be better or some 15" M&H drag slicks..... not cheap but will knock a full second at least off that time i reckon.
I went over to 14" mickey thomson drag slicks & my time dropped from 14.01 to 12.78 in a matter of about 5 runs.. I dropped straight into the 13's, then a cheeky jet change in the carb saw the 12's :cool:
dave r5
« Reply #8 on: 13:18, Fri 19 June 2009 »
any 1 got a price on the sliks  ?
its geting maped next month so will try agen then
« Reply #9 on: 14:06, Fri 19 June 2009 »
ive got a mate whose got 185 60 13 A048's yokies they were fitted to his westfield were he managed a 1m.24s lap time at sneterton  they have coverd 25laps , there not slicks but they come fitted on EVO 8's standerd
« Reply #10 on: 14:58, Fri 19 June 2009 »
They would be ok but he needs 15" at least as I think he has the big brakes on...
Try Andy Robinson Race cars, they import drag slicks, you cazn get dot radials or pure drag slicks from them, depends if you are going street class or not.
« Reply #11 on: 15:01, Fri 19 June 2009 »
Rob @ Backyard is more the person to comment actually as he's done alot more drag racing than me... Let's hope he sees this & has some comments :)
Rob@BYR
« Reply #12 on: 18:48, Mon 22 June 2009 »
Ask away... :)
Ps Yoko A048 wont work as a drag tyre, you prob can match them with a budget tyre to the 60ft... the best starter drag trye for the GT will be the 20" MT..... The MTs are capable of 1.7 60fts with a nice setup and a good torq range...
« Reply #13 on: 00:07, Tue 23 June 2009 »
your PS has been noted lol
 i never new tyres made so much difference lol . is this just a track thing or for road to??
« Reply #14 on: 09:10, Tue 23 June 2009 »
Both, but you can't run full slicks on the road, the closest is the Yoko AO48' or similar but they are soft & won't last long, they will also be dicey in the wet..
