Author Topic: idle problem, plz help  (Read 3012 times)
ains
« on: 20:43, Thu 12 March 2009 »
hi chaps, i brought a 5 gt turbo 4 days ago and so far im very happy with it. i'll put pics on here when it can work out how to, as im rubbish on computers :oops: !! anyway....when i start it, it runs at about 1300rpm. then when it gets warm it runs anywhere between 1300-2000rpm. its pretty arratic too.
i havnt really done much yet, but hoping you guys can help.
thanks
            ainsley
« Reply #1 on: 08:56, Fri 13 March 2009 »
Where are you in the country ??
Sounds like either the carb idle speed is too high, the choke is stuck open or the carb has an air leak/vacuum pipe is split somewhere.
ains
« Reply #2 on: 09:38, Fri 13 March 2009 »
im in kings lynn norlfolk.
ok, im gonna buy the trusty haynes book i think!
whitneyd
« Reply #3 on: 09:38, Fri 13 March 2009 »
Sounds like a vac leak to me too.
1995 Escort Cosworth
1994 Renault Express GTT
JK
« Reply #4 on: 17:26, Fri 13 March 2009 »
Quote from: "ains"
Trusty Haynes  :)  But cn be a bit vague in some places for the 5 turbo, definately worth having tho
I got 5 on it..
ains
« Reply #5 on: 17:31, Sat 14 March 2009 »
ive also noticed that when hot and been stood for a bit its hard to start. could this be because my perc fan is'nt connected? this is how i brought it. ive heard that they start fires?!
« Reply #6 on: 18:06, Sat 14 March 2009 »
I had this same problem buddy, the idle one. I changed my manifold to AEI hose for a new one and double checked everything was tight. I changed the one-way-valve to the servo too, only because I took it out to check it was working and snapped the thread off in the manifold when i was putting it back, not good :(
And my car takes a couple of turns to start up with out the perc fan, it can happen with it still fitted though.
« Reply #7 on: 18:17, Sat 14 March 2009 »
Check if the plate is there between the inlet manifold & carb bottom, i ran with no perc fan but had this in place & had no hot start probs..
« Reply #8 on: 18:26, Sat 14 March 2009 »
Quote from: "5teve L"
Is that the plastic one Steve?
« Reply #9 on: 18:47, Sat 14 March 2009 »
Err no..... that would be a bit of metal that acts as a heatshield ;)
« Reply #10 on: 20:23, Sat 14 March 2009 »
Ah, I don't think I have that one then, haha.
leonault5
« Reply #11 on: 19:25, Tue 17 March 2009 »
check the carb top for cracks. the sandard plastic ones can be a bugger.
ains
« Reply #12 on: 21:29, Tue 17 March 2009 »
cool, cheers. i checked for leaks but i can't notice anything, but ive never owned one of these, so cant be sure(i hav vw's usaully). i re-adjusted the idle to just over 1000rpm today, so i'll see wot happens next time i drive it lol
dunno if it matters or not but its got a k-tec fmic, twin dump valve's, cone filter and from wot i can tell standard turbo with a boost valve. it's running about 15psi. i dont wont the car to be boosting to high. is that boost ok?
« Reply #13 on: 08:38, Wed 18 March 2009 »
Remove the dump valves, the diaphrams may be split & leaking ;)
ains
« Reply #14 on: 11:20, Wed 18 March 2009 »
ok,what should i look for when i take them off?
