Author Topic: When Fitting Gaskets  (Read 1103 times)
DanielSon-gtt
« on: 22:38, Sat 28 February 2009 »
Do You Need Any Sealent On Any Gaskets At All Rockercover,waterpump,manifold..?
Go Boost Or Go Home
Re: When Fitting Gaskets
« Reply #1 on: 22:46, Sat 28 February 2009 »
Quote from: "DanielSon-gtt"
a little on water pump nothing on anything else
DanielSon-gtt
« Reply #2 on: 23:15, Sat 28 February 2009 »
Ok Thanks I Ashume The Stuff From Cgb Good Anouth To Use
Go Boost Or Go Home
« Reply #3 on: 00:13, Sun 01 March 2009 »
I've never used sealant on the water pump gasket, hasn't caused any problems. Not sure why that was suggested.
Just make sure the faces are clean.
« Reply #4 on: 08:07, Sun 01 March 2009 »
If you have all the gaskets then you don't need sealant. You can use sealant on the water pump instead of the gasket...
