Welcome,
Guest
. Please
login
or
register
21:06, Wed 03 March 2021
Home
Help
Search
Login
Register
RENAULT5GTTURBO.COM
GENERAL
General Chat
When Fitting Gaskets
« previous
next »
Print
Pages: [
1
Author
Topic: When Fitting Gaskets (Read 1049 times)
DanielSon-gtt
200BHP Senior Member
on:
22:38, Sat 28 February 2009 »
Do You Need Any Sealent On Any Gaskets At All Rockercover,waterpump,manifold..?
Logged
Go Boost Or Go Home
Re: When Fitting Gaskets
Reply #1 on:
22:46, Sat 28 February 2009 »
Quote from: "DanielSon-gtt"
a little on water pump nothing on anything else
Logged
DanielSon-gtt
Reply #2 on:
23:15, Sat 28 February 2009 »
Ok Thanks I Ashume The Stuff From Cgb Good Anouth To Use
Logged
Go Boost Or Go Home
Global Moderator
Reply #3 on:
00:13, Sun 01 March 2009 »
I've never used sealant on the water pump gasket, hasn't caused any problems. Not sure why that was suggested.
Just make sure the faces are clean.
Logged
Global Moderator
Reply #4 on:
08:07, Sun 01 March 2009 »
If you have all the gaskets then you don't need sealant. You can use sealant on the water pump instead of the gasket...
Logged
Print
Pages: [
1
« previous
next »
RENAULT5GTTURBO.COM
GENERAL
General Chat
