Author Topic: oil cooler  (Read 2719 times)
DanielSon-gtt
oil cooler
« on: 01:54, Wed 25 February 2009 »
What Oil Cooler Do People Recomend And What Number Of Rows
Is a Universal One Much Cop As I Was Told That An Astra Oil Cooler From a Gsi Would Do The Job
Would It Just Be a Case Of Buying a Renault 5 Sandwich Plate And Hoses And Bobs Your Uncle
Go Boost Or Go Home
« Reply #1 on: 14:29, Wed 25 February 2009 »
iam using a 13 row universal made with a oil stat to make sure the oils not to cool,
people mainly go for the kit from mocal
DanielSon-gtt
« Reply #2 on: 14:33, Wed 25 February 2009 »
An Oil Thermostat Is Prity Much Needable Then So You Dont Over Cool The Oil How Much Did Yours Set You Back As I Been Pricing One Up From Cgb With Thermo On Ruber Hoses Is £125 But If You Want Braided Its £150
Go Boost Or Go Home
« Reply #3 on: 14:35, Wed 25 February 2009 »
sounds about right mine was cheaper cause i got a company to make it to what i wanted (good friends that helped me do this)
DanielSon-gtt
« Reply #4 on: 14:38, Wed 25 February 2009 »
How Is The Thermo Fitted Can You Put Your Own Inline
Go Boost Or Go Home
« Reply #5 on: 14:48, Wed 25 February 2009 »
you can they are just push on fittings fittings for both the oil lines going from sandwich to the stat then from the stat to cooler
DanielSon-gtt
« Reply #6 on: 16:11, Wed 25 February 2009 »
Wouldnt It Be Cheaper To Get a Custom One Made From Radtec
Go Boost Or Go Home
« Reply #7 on: 16:12, Wed 25 February 2009 »
they want around 189.99 + vat and delivery
DanielSon-gtt
« Reply #8 on: 16:15, Wed 25 February 2009 »
I Was Just Pricing Up The Bits To See If It Would Be Cheaper Because They Do Coolers For Like £30
Go Boost Or Go Home
« Reply #9 on: 16:24, Wed 25 February 2009 »
No need to buy a sandwich plate, it's already got one fitted for the original oil cooler.
DanielSon-gtt
« Reply #10 on: 16:28, Wed 25 February 2009 »
So All You Need Is 2 Pipes A Cooler And A Thermostat
Its Just Buying aThe Rite Threads On The Fitment Or Are They All The Same
Go Boost Or Go Home
« Reply #11 on: 16:30, Wed 25 February 2009 »
Thread sizes might vary but take your sandwich plate and oil cooler to somewhere like Pirtek and they will knock you some lines together there and then.
Not bad on price either from my experience.
DanielSon-gtt
« Reply #12 on: 16:44, Wed 25 February 2009 »
Whats Not A Bad Price For Oil Lines
Go Boost Or Go Home
« Reply #13 on: 16:46, Wed 25 February 2009 »
for the kit
DanielSon-gtt
« Reply #14 on: 17:03, Wed 25 February 2009 »
Well If I Was To Get A Oilcooler From Rad Tec Tey Do 7rows For £38 And Go Down Pirtek How Much Will They Charge To Make Some Pipes Up
And For Me To Buy A Termostat Would It Be The Same Price Just To Buy One From Cgb
Just Trying To Shave Some Pennys Off a Sum Iv Been Pricing Up
Go Boost Or Go Home
