Author Topic: HELP - Car wont run  (Read 4292 times)
stoneboy2k3
HELP - Car wont run
« on: 22:09, Fri 09 January 2009 »
Right heres whats happening, all help will be truly helpfull.....
Its pretty simple, the car only combusts when you turn the key over....when you rev it up all it does is combust quicker but the car will not continue combustion when you stop trying to start it, it will simply turn straight off....
Ive had the carb off and cleaned it, it fuels and checked all the leads
i havent got a clue whats going on
so plz HELP MEEEEEEEEEEEEEEEEEEEEEEE
JK
« Reply #1 on: 12:01, Sat 10 January 2009 »
sparking ?
I got 5 on it..
« Reply #2 on: 12:05, Sat 10 January 2009 »
I'm not entirely sure what you mean?
The car wont idle?
« Reply #3 on: 14:27, Sat 10 January 2009 »
Are you getting a spark at the plugs?
Are you getting fuel all the time
Check the dizzy cap itn't corroded, check the plugs,it's prob the TDC sensor though by the sounds of it.
stoneboy2k3
« Reply #4 on: 18:03, Sat 10 January 2009 »
yeah spark at the plugs but it isnt constant tho, the dizzy leads plugs are all new
« Reply #5 on: 18:13, Sat 10 January 2009 »
Now i understand!
TDC sensor or Renix unit is playing up by the sounds of it, make sure the connections are nice and tight before you right anything off.
stoneboy2k3
« Reply #6 on: 19:25, Sat 10 January 2009 »
wheres the renix thing mate?
axnutty
« Reply #7 on: 19:35, Sat 10 January 2009 »
On the bulkhead.
stoneboy2k3
« Reply #8 on: 19:37, Sat 10 January 2009 »
where bwts tho ? i ent into mechanics
« Reply #9 on: 19:41, Sat 10 January 2009 »
It depends if it's Phase 1 or 2.
Phase 1 cars have it on the bulkhead right above the turbo, Phase 2 have it inside the bulkhead next to the battery, if you still have the original plastic scuttle panels you might have to pull it off to get access to it. If you follow the long HT lead it will take you straight to it.
stoneboy2k3
« Reply #10 on: 20:05, Sat 10 January 2009 »
how much is a new one of them?
blueredblue2008
« Reply #11 on: 21:14, Sat 10 January 2009 »
hi m8y
smithsgtt had sum for sale and he had a couple of different ones give him a pm and i'm sure he will sort you out with one :lol:
« Reply #12 on: 21:22, Sat 10 January 2009 »
Quote from: "blueredblue2008"
hi m8y
[you]smithsgtt[/you] had sum for sale and he had a couple of different ones give him a pm and i'm sure he will sort you out with one :lol:
nope no longer sold all 5 to a guy from germany for 25 the lot plus the postage and packaging
« Reply #13 on: 22:54, Sat 10 January 2009 »
Quote from: "stoneboy2k3"
I would try the TDC sensor first, these are more likely to fail.
« Reply #14 on: 08:12, Sun 11 January 2009 »
Quote from: "smithsgtt"
hi m8y
25 the lot  :shock:  Last one i sold went for 50 + postage to portugal.
