Author Topic: my '86 restoration - keeping the dream alive (09/10/2010)  (Read 97501 times)
Ruske
Re: my '86 restoration - keeping the dream alive (15/03/2010)
« Reply #210 on: 00:08, Tue 16 March 2010 »
LOOOOOOL
jayy.cfg
« Reply #211 on: 16:21, Wed 17 March 2010 »
i take it you sprayed the engine bay yourself ?
does make me want to chop my 1 up and hurry up and do it quickly.
« Reply #212 on: 19:49, Fri 19 March 2010 »
jayy.cfg - yeh i painted that myself with cans. came out really good although ive got to touch it up in a couple places before the engine goes in.
Re: my '86 restoration - keeping the dream alive (21/03/2010)
« Reply #213 on: 19:33, Wed 24 March 2010 »
some progress from the weekend
had some spare time at work so polished my alternator
finished putting to gether my brakes and made new brake pipes
passenger brake pipe is 90% hidden in the engine bay
and relocated header tank and brake resivoir
and then spent ages bleeding the brakes.
im currently waiting on my new coolant pipes to arrive from samco (warrenty replacements)
also waiting for my custom ali intercooler pipe work to be made
« Reply #214 on: 20:10, Wed 24 March 2010 »
Looking fantastic matey loving the White bay you and Mark are putting loads of work into the old girl but nice to see her on the road.
hondaman
« Reply #215 on: 09:41, Thu 25 March 2010 »
i always have an absolute apreciation for work like this well done mate
Arturas-zender
    • http://www.emusic.lt
« Reply #216 on: 07:29, Fri 26 March 2010 »
Hello.
You might have problems with inlet manifold. I did the same , by insulating exhaust manifold where it have a contact with inlet manifold , visually everything seemed fine , but after I started the car , had some fuel leak from there  :roll: so I had to cut wrap in that area  :wink:
« Reply #217 on: 21:57, Sat 10 April 2010 »
engines in  :D
« Reply #218 on: 22:29, Sat 10 April 2010 »
Looks clean and tidy.
About the brake fluid res, did you have to make a new pipe for that or does the original reach?
I have to take my engine out sooner or later and it could do painting to match the outside, perfect time to move some brackets around i think.  8)
Re: my '86 restoration - keeping the dream alive (18/04/2010)
« Reply #219 on: 20:29, Sun 18 April 2010 »
big update
after a brake fluid leak from a dodgy master cylinder, i ended up having to respray the engine bay again. this time it has come out much better though.
then gave the subframe a lick of black paint
finally a master cylinder that doesn't leak
engine off the stand and flywheel and clutch on
gearbox on
and in the bay for the final time
and on with my hoses, courtesy of samco replacing my stained yellow hoses free of charge
and after some messing around, decided to keep the header tank back in the std place or there would be too much pipe work on the drivers side
intercooler painted black to hide it behind the bumper
scuttle covers
new boost pipe run
and thanks to a good friend, its now also got a bonnet bra!!
i couldnt be euro without one
next up is bleed the brakes and adjust the gear linkage then its back on with the borbets
 :D
« Reply #220 on: 20:35, Sun 18 April 2010 »
the originals just reach. i did try my own pipe work but it was hard get it to seal on the master cylinder. you do need to drill a hole in the firewall for the pipes to run through
« Reply #221 on: 22:25, Mon 19 April 2010 »
Wow respect for all your hard work Jim - looks awesome. I think you'll be competing with GTTboost in terms of mintness!*  8)
« Reply #222 on: 18:52, Tue 20 April 2010 »
it better all be worth it lol :lol:
« Reply #223 on: 21:25, Wed 21 April 2010 »
small update
finished boost pipe run
also bought some nice new t'clips for the boost pipes and a new airfilter as the old piperx was looking abit old lol
« Reply #224 on: 22:47, Wed 21 April 2010 »
Looking good matey loving the White bay
