Author Topic: my '86 restoration - keeping the dream alive (09/10/2010)  (Read 111387 times)
Re: my '86 restoration - keeping the dream alive (02/01/2010)
« Reply #180 on: 18:50, Tue 02 February 2010 »
gaz - the vnt is awesome once set up but it can take abit of fidling to get it how you want it.
ryanreed
« Reply #181 on: 19:45, Tue 02 February 2010 »
nice work mate.another 5 kept alive!
gaz
« Reply #182 on: 19:57, Tue 02 February 2010 »
mines set up to come on boost at 2300 rpm n hit full boost at around 2900 rpm. not drove the car properly yet as im doing some work on it ready for better weather in may time. but i want to make sure fuelings set up first... but heard there a nitemare to get fueling set up?? so im just worried its going to break the bank?? lol :?
« Reply #183 on: 23:08, Tue 02 February 2010 »
sounds like its set up about the same as mine. mayb abit laggier.
my carb is set up to be safe at 20psi and i just run it on that fueling all the time
gaz
« Reply #184 on: 23:15, Tue 02 February 2010 »
sorry my mistake lol its set to come in at 1600 & hit full boost at 2500. did u set it up on a wideband? if so wot jeting have you got?? ive only just bought the car you see & want to get fueling set for frame of mind...
« Reply #185 on: 20:14, Thu 04 February 2010 »
one of my mates built the carb for me. hes done quite a few now and his 5 is awesome.
he normally brings his lc1 round and then do some roadtests to make sure it doesnt run lean under boost.
i would like to get a wideband afr sensor in there tho just to be sure
gaz
« Reply #186 on: 22:53, Thu 04 February 2010 »
ok thanks mate. its got the nut in the exhaust for a wideband so ill get 1 & probably get some 1 who knows what there doing. cgb motorsport said he would set it up for me so ill see what happens...
thanks
gaz
hondaman
« Reply #187 on: 22:57, Thu 04 February 2010 »
thats top work there mate, out of interest how easy is it to get the liners out of the block?
« Reply #188 on: 13:47, Fri 05 February 2010 »
Quote from: "hondaman"
Easy peasey, but the head needs to be off :D
hondaman
« Reply #189 on: 10:10, Tue 09 February 2010 »
this is epic  8)
« Reply #190 on: 15:32, Tue 09 February 2010 »
this is epic  8)
and close to being finished ;)
« Reply #191 on: 21:11, Tue 09 February 2010 »
now back on his wheels  :D
still a way to go though
Re: my '86 restoration - keeping the dream alive (09/02/2010)
« Reply #192 on: 22:44, Tue 09 February 2010 »
new engine repainted black, then next was the oil pump (flash brings out some of the yellow on the edges. its not seen without the flash though)
then the sump
(where possible ive replace all bolts with allen key cap bolts)
head bolted down with 2 old bolts to stop the liners moving
chrome fan bracket
et15 7.5x16's with out the arches lol
after i cleaned out the garage of all the old rust
engine bay
carbon scuttle covers
prototype manifold (doesnt quite fit though)
intercooler remounted
and seeing as the wheels can be seen in the last pic, here he is seeing daylight for the first time in a few months
that was mondays work.
tonight i have started to sand back the strut tops and i have started to drill the hole for my boost pipe to go through, but as the battery in my drill died i didnt get very far . . .
more pics soon
 :D
« Reply #193 on: 00:00, Wed 10 February 2010 »
james, please dismantle fan from rad and paint the rad satin black  :lol:
« Reply #194 on: 10:59, Wed 10 February 2010 »
wow at them wheels .. there some thing different alright Lol
