Author Topic: my ginger GT Turbo  (Read 45221 times)
Re: my 5, my old campus and my winter hack...
« Reply #60 on: 12:04, Sat 31 October 2009 »
cheers dude :)
raider is proving to be awesome... been driving it since 1st sept with no real issues or problems, just keeps taking the abuse that i give it.... lol
its not even that bad on fuel! i may have to sell it soon tho as i'm considering changing careers and there will be more travelling involved, hopefully not but i'll have to see how it goes  :?
not going to do much to the raider, its a bit of a work beater so dont want to end up painting it nicely or i'll be in the same boat as my orange one (eg. weekend toy) and i'd have to buy yet another car! lol
olie_r5
« Reply #61 on: 18:47, Sat 05 December 2009 »
such a nice car! Love the bonnet graphic! did u design that yourself?
and also is the clio dash an almost perfect fit or do you have to tweek a lot
rover twin cam power \";)\"
eddy_gtt
Re:
« Reply #62 on: 17:07, Tue 22 December 2009 »
Quote from: "markeyturbo"
clio dash:
clio dash during lol:
are these a straight fit? how do the clocks work?
« Reply #63 on: 21:17, Sun 17 January 2010 »
been a while since i've been on here... so some updates:
bought some of this after xmas...
so now have this:
and a couple of work in progress's:
Ruivar
« Reply #64 on: 21:50, Sun 17 January 2010 »
Very nice! That's some beautiful work you've done there, mate  :D
What happens when you blow on fire?
linni
« Reply #65 on: 21:17, Wed 20 January 2010 »
mark is that bronze the factory colour of your 5 ?
looks very similar to mine but mines been painted every colour under the sun in its lifetime.
from what i can see in the beginning it was a tungy!
just wondering if you had the colour code for the bronze as ill be needing paint very soon  8)
cheers
linni
« Reply #66 on: 21:29, Wed 20 January 2010 »
hey markey lovin the carbon mate where did you get that kit from ? i can feel some carbon bits for my 5 and evo :lol:
jayy.cfg
« Reply #67 on: 07:42, Tue 13 April 2010 »
hey markey, i was wondering what wheels are on your car atm
« Reply #68 on: 00:43, Wed 14 April 2010 »
sorry for slow reply!!
Quote from: "linni"
cheers
linni
no its a custom colour, metallic orange with copper and gold pearl
its a mix of bits from different sources, should have some finished brake ducts in the next week or so :)
Quote from: "jayy.cfg"
none at the mo lol, the are ACE 239's i believe, but they are currently being refurbed for a slight update for this year
« Reply #69 on: 01:09, Wed 21 April 2010 »
mini update - will be able to post proper pics on sat once i get it back from carrera
its in having wheels redone, carbon canards on front bumper and few bits of paintwork touched up so its minty fresh again
this evening whilst it was in, replaced the rollcage and replace fogs for carbon ducts
jayy.cfg
« Reply #70 on: 19:08, Fri 23 April 2010 »
what u doing with your old cage then ?
LazaRs
Re:
« Reply #71 on: 21:37, Fri 23 April 2010 »
i'll have to dig out complete spec...
dished pistons
skimmed block and head to increase compression
modified combustion chamber but otherwise std head
balanced pistons, crank, L&b flywheel
std cam
VNT turbo running 14-27psi
TTS downpipe and K-tec side exit
volvo 440 clutch
MSM carb
CTD custom fmic intercooler to my design
CTD hardpipes
SFS hoses
aquamist water/methanol injection
close ratio gearbox from i think a R9 or R11
armtec limiter with flatshift
last dyno day made 217bhp and 256lb/ft torque.... with a std cam, manifold etc. etc.
have a CTM 293degree cam to put in next time she blows lol
Hi markey, just one quick quest.
You have mentioned that you got aquamist system on your GTT,
i was planning to get one to keep the temp. lower since i am building a car for the 1/4mile.. Do you reccomend them? Did you have any gains?
Thanks mate! regards!
« Reply #72 on: 16:38, Tue 27 April 2010 »
hey bud, i run a mix of 70% water 30% methanol in mine, to be honest it actually makes less power with the system on, but it does lower the temp of the intake charge, which reduces det, which makes it safer on big boost if that makes sense.
mine only switches on at 18psi so i dont use it for day to day running
i've got a DDS3 controller as well which is an amazing bit of kit, and if you get an aquamist definately get that to go with it :)
« Reply #73 on: 02:32, Mon 10 May 2010 »
few more pics of the latest additions:
wheel refurb (after my kerbing FAIL) now have inner rim orange as well
'x' rear cage and removed the 'fake' front half
front fog ducts and canards now fitted
and how it sits at the momento!
but still got this lot to fit
and.... my raider is back on 13's for a while
fin
DRAZEN NST
    • http://www.zafc.bigforumpro.com
« Reply #74 on: 15:25, Mon 10 May 2010 »
Very very nice!  :)
[size=200]NORTH SIDE TEAM Subotica [/size]
