If you are doing the wire swap then 19psi may be a bit high, it may det, you need to get a stethescope on it to check thats the only way of telling really.
It gives around 4 degrees of advance, if you adjust it via the TDC sensor itself (so it slides) then you can get up to 6 degrees of retard or advance IIRC.
HTH
Steve
I retarded mine when running 24psi manifold (around 27psi carb top).
